You are using an out of date browser. It  may not display this or other websites correctly.
You should upgrade or use an
alternative browser .
Solved   System Tray Notification
					I have a popup problem once again. Each morning I get a notice from the system tray about a blocked program...WinPatrol  Change Detection. I have WinPatrol Plus installed but it's been over a year since I had this similar problem and can't remember what I did to stop it. This is what it looks like...
					Dell XPS 435MT
					2.67 gigahertz Intel Core i7 920
					Dell Inc. 0R849J A00
					6G
					ATI Radeon HD 3650
					DELL SP2009W
					SAMSUNG HD642JJ
640G
					10Mbps
					Dell XPS 435MT
					6G
					ATI Radeon HD 3650
					DELL SP2009W
					SAMSUNG HD642JJ
640G
					10Mbps
					Over 120 views and no one knows...interesting. This place is about as useless as I remember.
					Dell XPS 435MT
					6G
					ATI Radeon HD 3650
					DELL SP2009W
					SAMSUNG HD642JJ
640G
					10Mbps
					Sorry that it took so long for a reply, there is no need to post uncomplimentary remarks, however. A lot of the views are from non members that cannot reply, but are looking for help by reading the posts given to others.
That being said, allow me to try and help. If you boot in clean boot mode, and the problem is no longer present, you
can determine the source of the problem, restoring the programs one by one and testing each time for the problem. Hope this helps
Troubleshoot Application Conflicts by Performing a Clean Startup - Windows 7 Help Forums
If the problem is actually caused by Win Patrol, try setting Win Patrol for a delayed start rather than a start up at boot.
					My apologies. Things have been aggravating all the way around and it boiled over to the computer. I've had vascular problems and can't sleep at night more than a couple hours for a week as my foot goes to sleep when I lay down, burns and tingles due to artery blockage. Not anyone's problem but may have been part of the reason for my demeanor.
					Dell XPS 435MT
					6G
					ATI Radeon HD 3650
					DELL SP2009W
					SAMSUNG HD642JJ
640G
					10Mbps
					Sorry to hear that. Lets try to solve the computer problem. Let me know how my suggestions work out.
					You can create a start-up Task in "Task Scheduler" for the program and it should bypass Defender.
					Alienware Aurora R4
					Intel Core i7 4960x
					Alienware 0FPV4P
					8GB Corsair 2333MHZ
					GTX 760
					Soundblaster Recon 3D PCie
					Dell U2312HM
					1920x1080
					Samsung 840 PRO SSD
					Alienware Aurora R4 ALX
					Alienware Watercooling
					Alienware Tactx Mouse
					Alienware Tactx Keyboard
					162MB DL 12MB UP
					HP-Pavilion m9280.uk-a
					ASUS NVIDIA Geforce GTS450
					HP w2408 24.0" (Dual monitor)
					1920 * 1200, 1920 * 1200
BluRay & DVD Weiters
					40 Meg
I'm not sure how to do that.
					Dell XPS 435MT
					6G
					ATI Radeon HD 3650
					DELL SP2009W
					SAMSUNG HD642JJ
640G
					10Mbps
			~~тσωηsвg~~
					You can remove winpatrol or change it's settings so that it doesn't alert you about block programs.
					Operating System
					Windows 8.1 Industry Pro x64
					HP Pavillion Elite HPE-250f
					8 gb
					ATI Radeon HD 5770 1 gb ram
					Alienware 25 AW2521HF
					1920x1080 &1680x1050
					1 TB x2
					Operating System
					Dell Poweredge T140
					8GB 2666MT/s DDR4 ECC UDIMM
					1 TB & 360 GB x2
					WinPatrol is not the one that's doing the blocking, it's Windows that's blocking WinPatrol Background Change Monitor.
					Dell XPS 435MT
					6G
					ATI Radeon HD 3650
					DELL SP2009W
					SAMSUNG HD642JJ
640G
					10Mbps
 Have you tried my method yet?
					Alienware Aurora R4
					Intel Core i7 4960x
					Alienware 0FPV4P
					8GB Corsair 2333MHZ
					GTX 760
					Dell U2312HM
					1920x1080
					Samsung 840 PRO SSD
					162MB DL 12MB UP
					Yes, but got a little stymied when I got to Program/Script. I'll have to wait till I shut down again to see if it works.
					Dell XPS 435MT
					6G
					ATI Radeon HD 3650
					DELL SP2009W
					SAMSUNG HD642JJ
640G
					10Mbps
					Hi
Look here & try the suggested solution, Run task as an administrator...
WinPatrol Support
					40 Meg
					Thank you, sir. That worked!
					Dell XPS 435MT
					6G
					ATI Radeon HD 3650
					DELL SP2009W
					SAMSUNG HD642JJ
640G
					10Mbps
