Taskbar problem
wowhelper
When right clicking the taskbar and selecting properties I get an error popup
saying: "This operation has been cancelled due to restrictions in effect on this computer.Please contact your system administrator."
I have downloaded a theme but it wasn't working so i deleted! After this the above is happening.
Please Help Me :(
That would probably fix it. What program was the theme for? And it sounds more like an administrator disabled your ability to change computer settings. Do you have an administrator account?
    Dell Inspiron 1545
    Intel Core 2 Duo T6400 @ 2.00 GHz
    DELL - 27d90219 Phoenix ROM BIOS PLUS Version 1.10 A05
    Generic PnP Monitor (DPMS), 15.3" (34cm x 19cm)
    1366x768
    Internal 320 GB Portable 320 GB used for separate storage of media, plugged into USB port as needed.
    Single built in fan
    Touchpad, + Logitech wireless mouse (USB)
    Built in
    ~150 kilobytes/sec DL
    Usually have low HD free space left (<10 GB), often left on overnight. I really push its capabilities.
Please Help Me :(
If you are the admin ( or one of the admins ), use this tutorial....
http://www.vistax64.com/tutorials/158622-taskbar-start-menu-properties-enable-disable.html
Note : use Method Two, click the Download button.
