Hi thare... i was wondering if any of you with triple sli config's have had the temp of your primary card about 20c higher than the other two. now i run all three of these on a 790i ftw digital from EVGA with a q6600 at 3.6 with 8 gb of DDR3 1800 Mhz from Corsair and my ambient temp is about 74c in my work room. before i upgraded to the 790i, i had a 680i sli that i tested 3 way sli on, which worked perfectly and those temps were all the same!... about 40-41c at idle and under load at about 55c. all of the temps for each card were the same and SLI was probably scaling pretty well.
But when i fired up my new 790i and enabled 3 way sli, popped in Fallout 3 and noticed that my temps were way uneven. 72c on the 1st card, 46c on the 2nd card, and 43c on the 3rd card. card fans were at 100% and the driver i used was 186.18. Card's 1 and 2 are running on pci-e 2.0 so if its the bandwidth diff. from the 3rd card thats making the difference, sucks for me because i cant disable it.
please give your opinions as to why this may happen. most of my games are all certified for SLI and have an SLI-enabled profile.
- JUST ME/Custom Built
- Intel(R) Core(TM) 2 Quad Q9550 E0 2.83 Ghz @ 4037.5 Ghz
- EVGA NFORCE 790I SLI FTW Digital PWM
- 8 Gig Corsair XMS3 DHX 1600 Mhz DDR3 CAS 9
- 2x GTX 480's w/ Koolance VID-NX480's
- Creative SoundBlaster X-Fi Titanium (non-Fatal1ty) Edition
- Acer P243W 24" Premium Series
- 1920 x 1200
- Seagate Barracuda 7200.11 1 TB HDD 32mb cache (3 Platters, 6 Heads model)
- PSU
- Ultra X4 1050W PSU 76A Rated 12V SLI
- Case
- Antec 1200 Full tower ATX case
- Cooling
- x2 Thermaltake Blue LED 120mm 2800rpm fans, Zalman CNPS 9900
- Logitech LX310 2.4Ghz Wireless Laser Mouse
- Logitech LX310 2.4 Ghz Wireless Keyboard
- 32mb Download, 12mb Upload from Comcast
- Other Info
- 300$ custom watercooling setup. Antec 1200 big boy Radiator, Dual bay XPSC reservoir with clear bubble window, OCZ hydropulse 800L/H 12v pump, 12 ft tygon 1/2" ID, 3/4" OD tubing, Feser One UV Green 1 L fluid. (and VID-NX480 waterblock)
