the audio service is not running
joshuasvc
Banned
hi my first post
right i have a gateway ma7 with vista basic x32bit about 8 mounths ago i noticed that my sound had gone:cry: i go to device maniger and it says this device is working then i go to the icon tray and hover over the speaker icon and it says "the audio service is not running " i dobble click on it and it says do you want to enable this service i click yes and i go round and round i have gone on about every weebsite no help
if you need any more info on my laptop im happy to help
ps i took off sp2 people say that helps but it dosent:D:D
thanksss
    gateway
Is it set to start in services?
Go to start type services.msc
Go to Windows Audio, Highlight it go to the start drop down box and set it to automatic.
Do the same to Windows Audio Endpoint.
Post back for more info.
    Lenovo Thinkpad T400
    LENOVO 64734VM
    Conexant 20561 SmartAudio HD
    15 inch
    Medium for New Zealand
hi my first post
thanksss
Hello joshuasvc,
Welcome to Vista Forums.
Have you re-installed your audio driver?
    HP Pavilion dv5 Notebook PC
    4.00 GB RAM
kurry many times thanks ill try ilikefree thing thanks have you had the same prob post me back with any thing elce =)
    gateway
right im not saying this is rong cos it seems logical but i went to servises and audio wasent in thair have i done any thing
thank you for quick reply wasent expecting one till nex week or somin lol bye
    gateway
OK, Go to control panel,classic view,sound.
If there is a speaker there does it have a green tick.
Try to right click and see if it brings up a menu (it should)
You could try sounds, and test a few in the sounds box
post back results
You should have had the sounds entries in services.msc as in this clip.
    LENOVO 64734VM
    15 inch
    LENOVO 64734VM
    15 inch
ok so i did that and it had a tick i did a test on all no sound thank you for all you contrabution and that you keep coming back to help me
    gateway
OK, Go to the speaker with the green tick,
right click and go to advanced, see if it is set to 24Bit 48000Hz and the exclusive section has both boxes checked.
In the levels menu see that the level is set to the right side (max)
You could run the speccy program and see who makes your chipset, and look at the sound section. Then go to their sites and download the latest chipset and sound drivers.
I will guide you in installing them once you have them.
Post back with results
I would reinstall SP2 as it helps to be as up to date as you can be.
    LENOVO 64734VM
    15 inch
I CANT SEND YOU THE PIC BUT ITS A
Unimodem Half-Duplex Audio Device ( I think)
I ASLO GOT DRIVER GENIUS AND UPDATED EVERYTHING AND CHIPSET NOW WHAT CAN I DO
    gateway
    LENOVO 64734VM
    15 inch
You can search for your computer model here and download the driver from this site Unimodem Half-Duplex Audio Device driver
They are free.
EDIT: Have you installed the drivers or are you waiting for instructions?
    LENOVO 64734VM
    15 inch
ok thanks
managed to get the crack and product key 4 free and it has worked i can give u the sights for it if you want it realy helps
i
    gateway
    LENOVO 64734VM
    15 inch
i have in stalled all updates for chipsets allsorts no sound updates just getting driver detective key gen so it can do what it needs to do with out all this bout buying it lol
    gateway
Gateway Support Drivers & Downloads
This is the manufacture's site and you should be able to find it here, although I can only see XP versions.
EDIT: Don't mention cracked software on this site or we won't be able to help you. Against the rules, sorry:D
    LENOVO 64734VM
    15 inch
In device manager, system devices, do you have a sound entry there.
If so try to update its driver as well.
    LENOVO 64734VM
    15 inch
