Torrent stuck?
Hi. Now First of all what is a torrent. I dont know. secondly in the last few months iv had a torrent appear on my desktop and i have no idea where it came from. I cant delete it and it says it is not located on the desktop when it so it cant delete. Can someone help me please as i havent got a clue what it is or where it came from. also the name of it is
"[Torrentsworld.net] - Euro Truck Simulator mods.torrent"
thankyou
matt
PS im really sorry if this is in the wrong place. if it is can someone please move it. I tried looking and thought this would be the best place
Hello matthewthebrave, welcome to Vista Forums!
Not sure this will help but it's worth a go; download and install the free version of Malwarebytes from the link below, then run a full scan to see what it comes up with, if it finds anything run several scans till they turn up clean; be sure to post back to keep us informed.
Malewarebytes Free Virus Scanner
    * BFK Customs *
    Intel C2Q 9550 Yorkfield
    ASUS P5Q Pro
    8GB Dominator 8500C5D
    XFX ATI 1GB 4870 XXX
    Realtek HD 7-1
    1920x1080P & 1920x1200
    Corsair 620HX
    CM Cosmos RC-1000
    Razer Diamondback 3G
    HP Enhansed Multimedia
    18.6Mb/s
    My First Build ;)
OK mate, we'll be here.
    * BFK Customs *
    ASUS P5Q Pro
    Realtek HD 7-1
    Corsair 620HX
    CM Cosmos RC-1000
    18.6Mb/s
    My First Build ;)
Basically, I havent been able to install malware bites as im not as admin and my parents dont like me installing things they dont know what it is. Iv tried to get rid of it but as iv said, i cant seem to find it in a search and i cant delete it due to the fact it says "this file is no longer located on the desktop". Does anyone know how to get rid of this thing I have no idea what it is.
thanks
matthewthebrave
Do You Mean Malwarebytes?
Have you explained that it helps PROTECT the Computer
If you would still Like to Uninstall Malwarebytes then Please go to Start>Control Panel (Classic View)>Programs and Features
Then Find Malwarebytes in the List and Right click then click Uninstall
Hope This Helps,
Josh
    Intel Core i5 2400 @ 3.10GHz
    Foxconn H67MP-S/-V/H67MP
    8.0GB DDR3 @ 665MHz (2GBx4)
    AMD HD Radeon 6870
    SMB1930NW (1440x900@60Hz)
    Novatech Night
    Dell HID-compliant mouse
thankyou
matt
A Torrent is a File that tells the Computer were to receive a file from the Internet
For Example if there is a Document on the Internet that I would Like but I do not know were it is or it is stored on a Private Server connected to the Internet then you can use a Torrent File to Find it and Download it
Many Thanks,
Josh
    AMD HD Radeon 6870
    Novatech Night
OP..... have you run windows defender? Its preloaded with vista, or try using housecall.trendmicro.com
It's a online virus and malware remover.
    Dual L5639 // i7 950 @ 4.0Ghz
    gtx 560 ti // gtx 260-216
    Dual 22" // Headless
thanks, but are you aware of how i get rid of this torrent??? because iv downloaded some free file destroyers. but guess what. when i try to destroy the file, it says it is no longer located on the desktop and i cant find it anywhere els. I personally dont see how i will be able to get rid of this. does anyone els have any ideas?
What we are thinking is you picked up a virus and/or malware, which is why you can't get riid of it.
You can try booting into safemode, and delete it through the user profile path
Thanks for your help. two things. How do you boot into safe mode on a windows vista pc? iv only done it once many years ago and iv forgotton. and how do i delete it through the user profile path?
thanks again for your help
Safe mode is usually f8, and by user path i mean by using windows explorer zand going into
C:\Users\Your Name\Desktop
Ok,
How long has this PC been turned on for?
Right mouse & refresh or press F5 & see what happens?
    HP-Pavilion m9280.uk-a
    ASUS NVIDIA Geforce GTS450
    HP w2408 24.0" (Dual monitor)
    1920 * 1200, 1920 * 1200
    40 Meg
thanks, but iv tried this and i get the same message.
heres a screen clipping of when i try to delete the torrent:
if no one has any ideas or suggestions then dont worry about it. I have had this problem for months and havent figured out how to get rid of it and wouldnt be supprised if no one els can help.
thanks again
on an open part of your desktop i.e. not on an icon. Please press right mouse button & refresh (See the picture): -
    40 Meg
I have tried this. Still will not let me delete it. what i think has happened. is that its put an icon on my desktop but no file. i wish it would just let me delete it even if it is "apparently" not located on the desktop
OK,
Can you select it & select properties to find its location?
Please post a picture of what you see, Desktop & properties!
    40 Meg
go to the Start button & right mouse
Explore
move down & click on desktop, then post that picture please.
    40 Meg
