Hello all I am having quite the troubles with using my tv as a monitor my tv is an High def 27 inch RCA tv, It has a VGA port on it and considering my cable that im using is male going into the female output on the graphics card and being male on the other end I had bought a DVI female to VGA male so that I could possibly get it to work.
I put the attatchment I bought into the VGA port on my tv and plugged the male DVI into the female DVI and I switched my input to PC but I get no signal,
Any ideas?
Any ideas?
- Customized
- Intel Q6600
- P5Q Pro
- 6 gigs
- XFX GTX260
- on board
- RCA 27", Viewsonic 19"
- 1168x664
- 456 gigabytes
- PSU
- 600 StealhXstream
- Case
- NXZT hush
- Cooling
- Fans
- Razer DeathAdder
- Razer Lycosa
- Don't know
