TV Wonder Pro, IDE Controller Card
Platapus
I am only having two driver problems. One is with my ATI TV Wonder Pro card. It finds the driver, but it says that it encountered an error and it won't install. The other driver problem is with my Ultra ATA IDE COntroller Card, which allows me to have 2 more hard dives. I can;t get the drivers for it loaded, so 2 of my hard drives aren;t seen. Please Help.
when you boot up hit f8 to go in to the vista menu and hight light disable driver signing or similar near the bottom of the menu
when booted up see if the drivers will load if it works you can run this command at an elevated command prompt and you wont need to do the f8 at boot up
Bcdedit.exe /set TESTSIGNING ON
    PHENOM II X4 Quad Core 965 Black Edition CPU, 3.40 GHz
    GA-MA790FXT-UD5P
    G.Skill 4GB (2x XMS3 2GB) PC-12800 (1600MHz
    nvidia 9500 gt
    on board
    T231H / X243H ACER
    1980x1050
    Hitachi 500 samsung 1terabyte wd 750
    550 watt
    cooler master
    stock
    microsoft
    logitech
    8000 dl 356 ul
    booting xp32 2x dual pci-e digital tv tuners
    xp pro v 1xpci digital tv tuners
    vista ultimate 64 1x pci sat tuner
    win7 64
    win8 64
