Hi there, I'm having massive issues with the UAC on home premium. It seems to have stopped working properly and I need assistance in order to fix it. I found a forum thread that showed how to reset the UAC back to default settings, however that didnt work. The log output is as follows:
scesrv.log
November-11-09 11:44:13 PM
----Configuration engine was initialized successfully.----
----Reading Configuration Template info...
----Configure User Rights...
SeImpersonatePrivilege must be assigned to administrators. This setting is adjusted.
SeImpersonatePrivilege must be assigned to SERVICE. This setting is adjusted.
Configure S-1-5-19.
Configure S-1-5-20.
Configure S-1-5-32-544.
Configure S-1-5-32-551.
Configure S-1-5-32-559.
Configure S-1-5-32-545.
Configure S-1-1-0.
Configure S-1-5-6.
Configure S-1-5-21-291580870-426939062-1474930274-501.
Configure S-1-5-32-555.
User Rights configuration was completed successfully.
----Configure Group Membership...
Configure Users.
Group Membership configuration was completed successfully.
----Configure 64-bit Registry Keys...
Configure users\.default.
Configure machine\software.
Configure machine\software\classes.
Warning 5: Access is denied.
Error setting security on machine\software\classes.
Configure machine\software\classes\.hlp.
Error setting security on machine\software\microsoft.
Configure machine\software\microsoft\drm.
Error setting security on machine\software\microsoft\windows.
Error setting security on machine\software\microsoft\windows\currentversion.
Configure machine\system.
Error setting security on machine\system\currentcontrolset\control.
Configure machine\system\currentcontrolset\control\class.
Configure machine\system\currentcontrolset\control\keyboard layouts.
Error setting security on machine\system\currentcontrolset\control\lsa.
Configure machine\system\currentcontrolset\control\lsa\data.
Configure machine\system\currentcontrolset\control\lsa\gbg.
Configure machine\system\currentcontrolset\control\lsa\jd.
Configure machine\system\currentcontrolset\control\lsa\skew1.
Configure machine\system\currentcontrolset\control\nsi.
Configure machine\system\currentcontrolset\control\nsi\{eb004a00-9b1a-11d4-9123-0050047759bc}\4.
Configure machine\system\currentcontrolset\control\nsi\{eb004a01-9b1a-11d4-9123-0050047759bc}\4.
Configure machine\system\currentcontrolset\control\nsi\{eb004a1c-9b1a-11d4-9123-0050047759bc}\0.
Configure machine\system\currentcontrolset\control\wmi\security.
Warning 2: The system cannot find the file specified.
Error enumerating info for machine\system\currentcontrolset\services\appmgmt.
Configure machine\system\currentcontrolset\services\scardsvr\security.
Error setting security on machine\system\currentcontrolset\services\stisvc.
Configure machine\system\currentcontrolset\services\stisvc\security.
Error enumerating info for machine\system\currentcontrolset\services\sysmonlog.
Configure machine\system\currentcontrolset\services\w32time\config.
Configure machine\system\currentcontrolset\services\w32time\timeproviders.
Configuration of Registry Keys was completed successfully.
----Configure 32-bit Registry Keys...
Warning 1336: The access control list (ACL) structure is invalid.
Error setting security on machine\software\Audible.
Configuration of Registry Keys was completed with one or more errors.
----Configure File Security...
Configure c:\program files\common files\speechengines\microsoft\tts.
Error setting security on c:\program files\common files\speechengines\microsoft\tts.
Configure c:\programdata\microsoft\windows\drm.
Configure c:\programdata\microsoft\windows\drm\cache.
Configure c:\windows\repair\default.
Warning 3: The system cannot find the path specified.
Error setting security on c:\windows\repair\default.
Configure c:\windows\repair\ntuser.dat.
Error setting security on c:\windows\repair\ntuser.dat.
Configure c:\windows\repair\sam.
Error setting security on c:\windows\repair\sam.
Configure c:\windows\repair\security.
Error setting security on c:\windows\repair\security.
Configure c:\windows\repair\software.
Error setting security on c:\windows\repair\software.
Configure c:\windows\repair\system.
Error setting security on c:\windows\repair\system.
Configure c:\windows\system32\wbem\mof.
Configure c:\windows\system32\windows media.
Error setting security on c:\windows\system32\windows media.
Configure c:\windows\syswow64\export.
Error setting security on c:\windows\syswow64\export.
Configure c:\windows\syswow64\ias.
Configure c:\windows\syswow64\wbem.
File Security configuration was completed successfully.
----Configure General Service Settings...
Configure sysmonlog.
Error 1060: The specified service does not exist as an installed service.
Error opening sysmonlog.
Configure SamSs.
Configure NtmsSvc.
Configure netddedsdm.
Error opening netddedsdm.
Configure netdde.
Error opening netdde.
Configure dmserver.
Error opening dmserver.
Configure clipsrv.
Error opening clipsrv.
Configure Browser.
General Service configuration was completed successfully.
----Configure available attachment engines...
Configuration of attachment engines was completed successfully.
----Configure Security Policy...
Configure password information.
Administrator account is disabled.
Guest account is disabled.
System Access configuration was completed successfully.
LSA anonymous lookup names setting : existing SD = D
D;;0x800;;;AN)(A;;0xf1fff;;;BA)(A;;0x20801;;;WD)(A;;0x801;;;AN)(A;;0x1000;;;LS)(A;;0x1000;;;NS)(A;;0x1000;;;S-1-5-17).
Configure LSA anonymous lookup setting.
Configure machine\software\microsoft\windows nt\currentversion\setup\recoveryconsole\securitylevel.
Configure machine\software\microsoft\windows nt\currentversion\setup\recoveryconsole\setcommand.
Configure machine\software\microsoft\windows nt\currentversion\winlogon\cachedlogonscount.
Configure machine\software\microsoft\windows nt\currentversion\winlogon\forceunlocklogon.
Configure machine\software\microsoft\windows nt\currentversion\winlogon\passwordexpirywarning.
Configure machine\software\microsoft\windows nt\currentversion\winlogon\scremoveoption.
Configure machine\software\microsoft\windows\currentversion\policies\system\dontdisplaylastusername.
Configure machine\software\microsoft\windows\currentversion\policies\system\legalnoticecaption.
Configure machine\software\microsoft\windows\currentversion\policies\system\legalnoticetext.
Configure machine\software\microsoft\windows\currentversion\policies\system\scforceoption.
Configure machine\software\microsoft\windows\currentversion\policies\system\shutdownwithoutlogon.
Configure machine\software\microsoft\windows\currentversion\policies\system\undockwithoutlogon.
Configure machine\software\policies\microsoft\windows\safer\codeidentifiers\authenticodeenabled.
Configure machine\system\currentcontrolset\control\lsa\auditbaseobjects.
Configure machine\system\currentcontrolset\control\lsa\crashonauditfail.
Configure machine\system\currentcontrolset\control\lsa\disabledomaincreds.
Configure machine\system\currentcontrolset\control\lsa\everyoneincludesanonymous.
Configure machine\system\currentcontrolset\control\lsa\fipsalgorithmpolicy\enabled.
Configure machine\system\currentcontrolset\control\lsa\forceguest.
Configure machine\system\currentcontrolset\control\lsa\fullprivilegeauditing.
Configure machine\system\currentcontrolset\control\lsa\limitblankpassworduse.
Configure machine\system\currentcontrolset\control\lsa\lmcompatibilitylevel.
Configure machine\system\currentcontrolset\control\lsa\msv1_0\ntlmminclientsec.
Configure machine\system\currentcontrolset\control\lsa\msv1_0\ntlmminserversec.
Configure machine\system\currentcontrolset\control\lsa\nolmhash.
Configure machine\system\currentcontrolset\control\lsa\restrictanonymous.
Configure machine\system\currentcontrolset\control\lsa\restrictanonymoussam.
Configure machine\system\currentcontrolset\control\print\providers\lanman print services\servers\addprinterdrivers.
Configure machine\system\currentcontrolset\control\session manager\kernel\obcaseinsensitive.
Configure machine\system\currentcontrolset\control\session manager\memory management\clearpagefileatshutdown.
Configure machine\system\currentcontrolset\control\session manager\protectionmode.
Configure machine\system\currentcontrolset\services\lanmanserver\parameters\autodisconnect.
Configure machine\system\currentcontrolset\services\lanmanserver\parameters\enableforcedlogoff.
Configure machine\system\currentcontrolset\services\lanmanserver\parameters\enablesecuritysignature.
Configure machine\system\currentcontrolset\services\lanmanserver\parameters\nullsessionpipes.
Configure machine\system\currentcontrolset\services\lanmanserver\parameters\requiresecuritysignature.
Configure machine\system\currentcontrolset\services\lanmanserver\parameters\restrictnullsessaccess.
Configure machine\system\currentcontrolset\services\lanmanworkstation\parameters\enableplaintextpassword.
Configure machine\system\currentcontrolset\services\lanmanworkstation\parameters\enablesecuritysignature.
Configure machine\system\currentcontrolset\services\lanmanworkstation\parameters\requiresecuritysignature.
Configure machine\system\currentcontrolset\services\ldap\ldapclientintegrity.
Configure machine\system\currentcontrolset\services\netlogon\parameters\disablepasswordchange.
Configure machine\system\currentcontrolset\services\netlogon\parameters\maximumpasswordage.
Configure machine\system\currentcontrolset\services\netlogon\parameters\requiresignorseal.
Configure machine\system\currentcontrolset\services\netlogon\parameters\requirestrongkey.
Configure machine\system\currentcontrolset\services\netlogon\parameters\sealsecurechannel.
Configure machine\system\currentcontrolset\services\netlogon\parameters\signsecurechannel.
Configuration of Registry Values was completed successfully.
Configure log settings.
Audit/Log configuration was completed successfully.
----Un-initialize configuration engine...
There are many lines in this log that says it couldn't set permissions to certain folders. This goes hand in hand with the main issue I've been having. The issue is that its not accepting the administrator password any longer when I'm running as a standard user - and trying to either install, or run certain software. I've even tried to reset UAC to default within an administrator account with the exact same message. Any help in attempting to fix this would be greatly appreciated.
Thanks
Carlo
scesrv.log
Configure S-1-5-19.
Configure S-1-5-20.
Configure S-1-1-0.
Configure S-1-5-6.
Configure Users.
Configure SamSs.
Configure NtmsSvc.
Configure netdde.
Configure dmserver.
Configure clipsrv.
Configure Browser.
D;;0x800;;;AN)(A;;0xf1fff;;;BA)(A;;0x20801;;;WD)(A;;0x801;;;AN)(A;;0x1000;;;LS)(A;;0x1000;;;NS)(A;;0x1000;;;S-1-5-17).Configure LSA anonymous lookup setting.
Thanks
Carlo
