Hi
Can anyone point me at an article that explains (reasonably simply) how the recycle bin works. I've read the Wikipedia article on it, and it helps, but not enough.
I'm trying to understand the following. I have just cleared the Recycle Bin using a Right Click on the desktop icon. The Icon changed to show an empty bin.
I have several physical disks, including an external USB disk, and as you'll see from the image, Disk cleanup says the bin is empty, the Desktop icon says its empty, but there is almost 4Gb in there according to Windows Explorer.
I'm on Vista Home Premium 32 SP2, and there is only 1 user on the PC. The External disk however has just had a copy of files with multiple users (from another PC) deleted.
I would like to better understand the workings, and the difference between "$RECYCLE BIN" & "Recycle Bin", so any articles on this would be welcome.
I also have a directory called "RECYCLER". I'd like to understand how that fits in.
Google provides so many, I thought I'd ask for help to find a decent one.
Thanks
Thanks
- Home made
- ASUS
- 4Gb
- GeForce 6600
- Soundblaster Audigy SE
- Samsung & Dell
- 1920 x 1080 & 1280 x 1040
- Seagate, Maxtor & Samsung
- PSU
- Enermax 500
- Case
- Antc
- MS
- MS
