Undo System Recovery
jp26198926
Hello
i used the full system recovery on vista home basic of my friend's laptop
and i forgot to backup his files..
is it possible to undo the system recovery like we always did in system restore.?
i ask this bcoz the laptop is not in my hand right now so i cannot look if there
is an undo option of system recovery.
thnx in advance...
thanks for your reply and for the info sir..
btw sir, regarding with software u recommend, is that can still recover the old one even if i save a new one with the same filename and location.?
once again sir thank for your reply.
Welcome to the Forum.
The software that was suggested is very good and restoring old files. It is used by many a this forum. Give it a try, it is very possible that you can recover. But, warning, the more you use the computer before trying to recover the less likely that you will have success.
