Hallo. I'm trying to run said title on Vista and there is an unusual problem that I come across once the game begins. Once the level has loaded the whole map is obscured as if by the 'fog of war' except for a little bit by the bottom of the screen. The problem is not solved by using the cheat removing the fog of war, as everything still remains dark, even though the map is revealed.
I haven't come across this problem after searching through various forums, so I thought I'd suggest it myself. I should mention I've tried downloading an illegal version to cheque there was nothing wrong with my copy and the same problem occured.
My imps are in the dark, and they will greatly appreciate your help.
cheers,
Ewan
cheers,
Ewan
