USB Devices SLOW System to a CRAWL
SD Cards, GPS, Cameras, Phone......Anything I plug into the system just slows it to a standstill. mouse stops, moves, stops. Usally clears up after about a 5 minute wait and the device is recognized. I have run Adware, Virus, Spyware, any scan I have and found nothing. Need advice.
HP a6030n
AMD Athlon 64 Dual Core
32 bit
Bill
    Hp a6030n
    Windows 7 Pro & 10 Pro
    HP Pavillion Elite HPE-250f
    8 gb
    ATI Radeon HD 5770 1 gb ram
    Alienware 25 AW2521HF
    1920x1080 &1680x1050
    1 TB & 500 GB
Strange that it clears up in about 5 min. Have you cleaned up computer recently ? Use ccleaner, and do a defrag , then restart, and see how long it takes a new device this time. My thinking is that too many files are being searched for it to connect everything up to just bing bang boom, So, clear trash out with a good cclean program, latest version, then defrag to get all files close together.
    Emachine ET 1161-05
    AMD Athlon 64 LE-1640
    1280x768 pixels
    ST316081 5AS SCSI Disk Device
    Tower
    Fan Speed 1247 RPM
    PS/2 Compatible Mouse
Downloaded CClean and ran it, that did it.
I have used DiscCleanup, and Defrag runs weekly, I guess the Windows cleanup,
don't really cleanup!
Thanks, Bill
    Hp a6030n
Woot Woot. glad that worked out for you.
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
