usb harddrive encloser
strycat
I've got a Rosewill Enclosure with a Western Digital "Green" SATA 2TB harddrive in it. When I plug it into my WinXP or Win7 boxes it works fine. However when I plug it into my Vista box, it will be assigned a drive letter but I'm told it is corrupted when I try to access it.
Vista is fully updated. I couldn't find any new drivers on WD's site.
What do I need to do to make it work?
Thanks in advance.
Try uninstalling and reinstalling the driver in device manager if you haven't tried yet.
You could also try checking the disk for errors.
I find that doing this via the Command prompt is quicker.
To Check a disk for errors via a command prompt:
Open an elevated command prompt.
Type in "chkdsk x:" (where x is the letter of your drive)
If errors are found, you could use the "chkdsk /f" command.
Hope this helps and I'm not providing you with useless info.
    Samsung R60 Plus
    Intel Core 2 Duo T7250 @ 2.00 Ghz
    2 GB DDR2 RAM
    ATI Radeon Xpress 1200 series
    Realtek Hi-def Audio
    Mobile PC Display
    Fujitsu 120 GB SATA drive
    100 mb/s
    South Korean model, Shipped from an english teacher half way across the world =P
