Solved Using another monitor with laptop
Have a second monitor that wont stay on when I plug it into the video card at the back of the laptop.. the picture from my desktop shows for about 5 seconds, laptop goes blank, then the other monitor goes blank and says "no signal" and goes into standby.
Then it's not recognized in display settings the ticked box reading "Extend the desktop to this monitor" is unchecked ..
Ideas?
When I click "Connect display" in the control panel, it says "Display Connected" so it does recognize it, just doesn't seem to come up on the other monitor..
    Advent (dixonsxp)
    Intel(R) Pentium(R) Dual CPU T2310 @ 1.46GHz
What does it say in device manager under the monitors tab?
    Lenovo Thinkpad T400
    LENOVO 64734VM
    Conexant 20561 SmartAudio HD
    15 inch
    Medium for New Zealand
Two "Generic PnP Monitor" tabs are there
I clicked Roll Back Drivers or somethin, now second monitor is working, but only showing what my laptop does, its not en extended monitor which I was looking for in the first place. And NO monitors show up in Device manager now, also only 1 monitor show up in the mobile pc screen and add monitor thing...
    Advent (dixonsxp)
Glad to hear that you've managed to solve the problem. Thank you for sharing the solution with us, I'm sure others will benefit from your information in the future :)
Tom
    Build #1
    Intel Core i7 3770K @4.4GHz
    ASUS P8Z77-V PRO
    Integrated on motherboard
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
