You should upgrade or use an
alternative browser .
I have several utility software programs. I am afraid to use any of them. I am using Vista home premium 64 bit. I bought this computer back in april. after I bought it I purchased a new program called Advanced System Optimizer. When I google for information on a quality utility program this program had very high recommendations. I also have Fit-It utilities 7 and an older version of System Mechanic. My computer is running slower now and I know it needs cleaning up. The last time months ago right after I purchase Advance System Optimizer I ran the registry cleaner and it reeked havok on my system. I called the company and they told me their program I purchased was not designed for 64bit systems. Of course they didn't refund my money. Question is: My computer needs cleaning up I can tell it is running slower than it used to. What utility program is out there that will work on my system. My system is Vista Home Premium 64 bit Intel core 2 Duo 2.6 GHZ. Thank for any advice.
HP Pavilion a6460t
Intel Core 2 Duo E4700 2.6 GHz
Pegatron Benecia
4 Gigs
Nividia 8500GT 512
HP w2207h 22 inch LCD
1680 x 1050
Hi MarshallMoore,
You might try running Disk Cleanup to start with , type it in the start search box, and run it when it pops up.
Programs that haven't caused me any problems on x64 are these free ones:
Glary Utilities
CCleaner - Download
You need to set up Ccleaner so it doesn't clear things you may want to keep, e.g. cookies, browsing history, and Windows Defender logs.
Hope it helps
siw2
Operating System
Vista
Intel E8400
ASRock1333-GLAN R2.0
4gb DDR2 800
nvidia 9500GT 1gb
Operating System
win7/vista
intel i5-8400
gigabyte b365m ds3h
ballistix 2x8gb 3200
Hello Marshall,
There are some great free ones you can try listed in this
link . Some of my favorites are:
Wise Registry Cleaner
Auslogics Disk Defrag
Auslogics Registry Defrag
CCleaner
You might also go through the items in this
tutorial to see how much it can help improve you computer's performance as well.
Operating System
1TB Samsung 990 PRO M.2,
4TB Samsung 990 PRO PRO M.2,
Galaxy S23 Plus phone
Operating System
Thank You for your help I gratefully appreciated it.
HP Pavilion a6460t
Pegatron Benecia
4 Gigs
Nividia 8500GT 512
1680 x 1050
You're welcome Marshall.
Operating System
Operating System
I have a sneaking suspicion all your optimisation apps is what's slowing down your machine.
Remember if it sounds too good to be true...it usually is.
Intel Q6600
ASUS P5K MBoard.
4G OCZ PC2 8500 Platinum
EVGA 8800GTS Vid Card
500G Seagate SATA
200G Seagate SATA
100G WD Caviar SATA
80G WD Caviar IDE
OCZ Elite 800W PSU
RaidMax Smilodon Case
Lite-On dual layer DVD burner X 2
Dos 6.2;Win2K;XP; &
Vista Ultimate 64Bit.
