Vista Business with minimum system requirements
Sally06
Hi
Can I go with minimum system requirements to install windows Vista Business. And will I be able to use different browsers if used minimum system configuration for installation. Such as I need Firefox, Internet Explorer etc..
Thanks!
Hi
Thanks!
Brink's tutorial is an excellent resource for speading up your Vista system.
But experience has taught me that the Windows "Minimum" system requirements are just barely enough to run the OS, let alone any usefull applications, such as Office.
In order to be useful, you should take the minimum specs for your chosen verion of Windows and double them up, or at the very least, better than what is stated. For example, if it says 1GB Memory, make it 2GB.
I've followed that train of thought for many years, and have yet to go wrong.
And welcome to the forum!
    AMD Phenom 9600 Quad
    ASUS MB-M3A32-MVP Deluxe/WiFi
    2 x A-Data 2GB DDR2-800
    ASUS ATI Radeon HD 2400PRO
    SAHARA 21"
    1600x1200
    800W
    Thermaltake Tai-Chi
    Tai-Chi Water Cooler
    Genius
    384kbps
