Vista display settings
djbillyd
I recently installed Vista Home Premium on a DELL Latitude C610, an oldie, but (at least until now) a goodie. It was a monster trying to install, because DELL doesn't offer support for that OS on that system. Now, that it is installed, I am unable to regulate the display settings. I have it set to "Turn off display" in 10 minutes in every "Plugged in Power Settings" option, but it doesn't turn the display off...EVER!
    DELL Dimension 3000 and Latitude c610
    3.0 and 1.00GHz
    Factory installed
    2.00 GB and 768 MB
    On board
    On Board
    Samsung941w; DELL
    1440x900; 1024x768
    Emachine ET 1161-05
    AMD Athlon 64 LE-1640
    1280x768 pixels
    ST316081 5AS SCSI Disk Device
    Tower
    Fan Speed 1247 RPM
    PS/2 Compatible Mouse
You have 2 problems:
1) No drivers for anything newer than XP
2) The system is so old it can't support anything newer than XP (and support of XP is questionable)
I recommend that you put whatever OS you had on it back or get a newer computer if you really want Vista.
    Windows 8.1 Industry Pro x64
    HP Pavillion Elite HPE-250f
    8 gb
    ATI Radeon HD 5770 1 gb ram
    Alienware 25 AW2521HF
    1920x1080 &1680x1050
    1 TB x2
    Dell Poweredge T140
    8GB 2666MT/s DDR4 ECC UDIMM
    1 TB & 360 GB x2
It is my suggestion, that you get a new computer with the awesome Windows Seven. Its Vista and a lot more. If you decide to go this route visit our affiliated website for help.
http://www.sevenforums.com/
I figured the thing was too old. In fact, I thought I said that the OS wasn't supported by DELL for this system. I have another laptop that I put "7" on, and I have two desktops with "7" on them, and I just love 'em. The Latitude thing is an experiment. Thanks for all of your responses.
    3.0 and 1.00GHz
    Factory installed
    2.00 GB and 768 MB
    On board
    On Board
    Samsung941w; DELL
    1440x900; 1024x768
You are very welcome. Dont forget to visit our Seven forum, to learn and just have fun.
It's not just that having Vista on that system isn't supported by Dell but that system doesn't have enough resources. It came with 2000 according to the specs. I doubt that any desktop or laptop released at that time has the capacity to support Vista. Actually you'd be better off with 7 on that system because it uses less resources than Vista however that system still has inadequate resources and there aren't any drivers.
    8 gb
    1 TB x2
    Dell Poweredge T140
    1 TB & 360 GB x2
Windows 7 Forums
Agreed
"It's not just that having Vista on that system isn't supported by Dell but that system doesn't have enough resources. It came with 2000 according to the specs."
Actually, it came with XP. And maybe my statement was too ambiguous, but "supported" meant that there are no drivers, or other firmware that makes vista TOTALLY compatible with the system, as delivered by DELL. The upgrades (hardware) that were readily available were accessed. As I said, it was an experiment. I'm not finished with it. Maybe something as simple as a display driver can be implemented, not just for this system, but for any older system.
My experiment is to see how much older systems will upgrade. I hope to supply some less fortunate kids with their own system one day. So, if you run across something that you believe would be useful, I would appreciate a 'holla'. And thanks for the reply.
    3.0 and 1.00GHz
    Factory installed
    2.00 GB and 768 MB
    On board
    On Board
    Samsung941w; DELL
    1440x900; 1024x768
Ubuntu by Linux is free .
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
Thanks for that. I have been saying that I was going to try that OS, but never got around to it. I'm building a desktop that I will try it on.
Thanks a bunch!
    3.0 and 1.00GHz
    Factory installed
    2.00 GB and 768 MB
    On board
    On Board
    Samsung941w; DELL
    1440x900; 1024x768
Well the page I saw said that it came with 2000 but the drivers went from 98 (maybe 95) all the way to XP.
    8 gb
    1 TB x2
    Dell Poweredge T140
    1 TB & 360 GB x2
I don't doubt it. The computer has an XP sticker, and an XP registration,... from DELL. The Latitude was, evidently, a popular computer back in '02. And, apparently, before that too!
    3.0 and 1.00GHz
    Factory installed
    2.00 GB and 768 MB
    On board
    On Board
    Samsung941w; DELL
    1440x900; 1024x768
By the way, without the service tag#, you can't get specific system info, only general stuff.
    3.0 and 1.00GHz
    Factory installed
    2.00 GB and 768 MB
    On board
    On Board
    Samsung941w; DELL
    1440x900; 1024x768
Thanks! That is a really cool tool.
    3.0 and 1.00GHz
    Factory installed
    2.00 GB and 768 MB
    On board
    On Board
    Samsung941w; DELL
    1440x900; 1024x768
You are very welcome. We at the Forum have a lot of tricks up our sleeves.
