Vista Help
Klewer
I have an Asus F5 Entertainment laptop which won't load. Someone else corrupted it and when it went to be turned on came up with a system repair due to software or hardware corruption. This would not work just got stuck at the loading bar. I tried the recovery disk from Asus this doesn't work. Tried to boot in safe mode also fails. Tried all Other options in boot manager without success. Any ideas on what next ? I don't have a full install disk of Vista. Also don't care about losing everything. Thanks for any help.
Maybe this will help
If you create a recovery DVD, you may be able to boot to recovery options
Create Recovery DVD
The Vista recovery disk is used to boot Vista when it won't boot - to run Startup Repair, System Restore, access a Command Line, Recover using a Vista Backup Image, etc.
System Recovery Options. Choose an option tht will not cause you to lose your stuff.
If Vista will not start now, boot the Recovery CD to run Startup Repair which automates System Restore as well as numerous other tests including System File Checker which can repair system files which are not corrupted beyond repair.
If Vista still will not start, try booting into Safe Mode to run sfc /scannow to repair System files.
Special Thanks Given to Seven Forums.
Below is a bulletin distributed by MS to explain the start up procedure when Windows will not boot.
  • Startup Repair. Startup Repair is a Windows recovery tool that can fix certain problems, such as missing or damaged system files, that might prevent Windows from starting. Startup Repair is located on the System Recovery Options menu, which is on the Windows Vista installation disc. If your computer has preinstalled recovery options, it might also be stored on your computer's hard disk. For more information, see Startup Repair: frequently asked questions and What are the system recovery options in Windows Vista? If your computer does not include Startup Repair, your computer manufacturer might have customized or replaced the tool. Check the information that came with your computer or go to the manufacturer's website.
  • Change restart settings in safe mode. If your computer is stuck in a loop where Windows fails, attempts to restart, and then fails again repeatedly, restart your computer in safe mode and select the Disable automatic restart on system failure checkbox. For more information, see Advanced startup options (including safe mode).
  • Reinstall. If no other options have solved the problem, and you are sure that your computer's hardware is functioning normally, you might need to reinstall Windows. A custom (clean) installation of Windows will permanently delete all of the files on your computer and reinstall Windows, so only use this option if all other recovery options have been unsuccessful. After the installation, you will need to reinstall your programs and restore your files from backup copies. For more information, see Installing and reinstalling Windows**.
I think your options are limited if it won't boot to safe mode.
You will need to use a rescue disc.
SystemRescueCd
EDIT:Beat me again Richard.
    Lenovo Thinkpad T400
    LENOVO 64734VM
    Conexant 20561 SmartAudio HD
    15 inch
    Medium for New Zealand
Yes, I did beat you, but I try to learn something from everyone. I copied and past this one LOL.
He is typing quick today!
    Hewlett-Packard SR5019UK
    M2N68-LA (Narra)
    2.50GB
    nVidia GeForce
    Realtec ALC888 Audio
    17" LCD Monitor
    160 Gb Usable Hard Drive
Thought you must have used cut and paste as it was a big post in the time it took me to write mine.;)
    LENOVO 64734VM
    15 inch
Try this: Power-on the PC and keep tapping F9. That should get you into the reinstallation procedure from the recovery partition.
    Dell
    Q6600
    HP w2207h
You will lose everything with the f9 tap, but it should work
Richard, he said that he does not mind to lose everything - that's why I suggested that.
Btw: congrats for your silver star. You look so "naked" now - LOL
    Dell
    Q6600
    HP w2207h
LOL, I have to get a bunch of pips to cover my nakedness, now. Thanks Wolfgang.
Until you get some pips to cover up I made this for you......
You can run but you can't hide from me.....
    HP Pavilon Elite
    ASUS eK Berkeley
    That's where I keep my beer
    MS WIRELESS
    MS WIRELESS
    AT&T Uverse DSL
Love it!!:roflmao:
    M2N68-LA (Narra)
    2.50GB
    nVidia GeForce
    17" LCD Monitor
LOL
No luck with the recovery disk, I burn and boot from CD and it then says Windows Loading Files and loads a Vista background and then just does nothing with the cursor in the middle of the screen.
Did you try the recover partition, as suggested by WHS?
Yes in the boot manager menu there is no option to select a recovery partition. There is an option to restore to previous working system but that will not load either. All the options in there I have tried and they all result in Windows beginning to load but only getting up a background and stopping.
OK, You do not have a rescue disc that takes you to a menu that will help,
You are unable to enter the restore partition either.
Your options are getting smaller.
If you need to save anything I would use a linux operating system.
Boot and run Linux from a USB flash memory stick | USB Pen Drive Linux
Then a reinstall with a retail version of Vista might be your best option.
Do you have a friend with a copy?
    LENOVO 64734VM
    15 inch
    LENOVO 64734VM
    15 inch
