Solved Vista keeps asking for drivers it doesn't need for WD MyCloud device
AndyTampa
I bought a Western Digital MyCloud NAS drive so I could have my own personal cloud on the internet. It works, but Vista seems to have a problem with it. Whenever I start or restart the computer, Vista asks me to install the drivers for it. The problem is that there aren't any drivers for it. It isn't even attached to the computer. It's on the network, but attached directly to my router. I can tell Vista to stop prompting me, but it will do it anyway on the next reboot.
Also, the device is listed twice in Device Manager under Other Devices with a warning icon. Is there any way to stop Vista from trying to install the drivers?
    Windows Vista Home Premium SP2, 32-bit
    Retrofitted Refurbished Gateway
    AMD
    ASUS M3A78-EM
    Acer 22-in Flat Screen Monitor
    Logitech M705 Wireless Mouse
    Logitech K350 Wireless Keyboard
AndyTampa
It appears I have accidentally solved my own problem thanks to the cable going out. We had some severe storms that knocked out my TV, phone, and internet. When they got it turned back on, I had to reboot my router. Now the NAS device no longer shows up in my Device Manager at all so it is no longer prompting me to install drivers. It is now a standalone machine connected to the network as it should be.
    AMD
    ASUS M3A78-EM
Ex_Brit
If you're going through hell, keep going
Glad you are OK now ;-)
    Win 10 Pro x64 x 2
    Alienware ALX x58
    2 x 500gb SATA II
    1 x 1TB SATA II
    1 external eSATA LaCie 3TB
    (Non-RAID)
    Unique
    1gb/s up and down
AndyTampa
I spoke too soon. It got even worse. Suddenly, while trying to figure out how to use the MyCloud device, accessing files on it from my Vista machine caused BSODs. After a couple of those, I tried a System Restore. Then I still got BSODs. I've figured out that I only get them when I try to access the files on the device. Then when looking at Device Manager, it started asking for the non-existent drivers again. I disconnected the device, uninstalled references to it in Other Devices of Device Manager and scanned for new hardware. Lo and behold, it still asked for drivers. I rebooted and decided to try to restore to an even earlier time and found all restore points, including this morning's, have vanished. The System Volume Information folder size is 36.3MB, and contains 14 files, 15 folders, but I can't access them.
Any ideas?
EDIT: I can access the folder now but I'm only seeing a bunch of folders from yesterday and the day before and three folders from 2012 that appear to be old restore points (RP1306, RP1369, RP1370) that don't even show up in System Restore. Most of the folders are empty.
    AMD
    ASUS M3A78-EM
Ex_Brit
Have you checked Control Panel > Programs and Features for unwanted programs that may be trying to get you to download drivers from one of those so-called driver detective sites?
    Win 10 Pro x64 x 2
    Alienware ALX x58
    2 x 500gb SATA II
    1 x 1TB SATA II
    (Non-RAID)
    Unique
    1gb/s up and down
AndyTampa
I just checked and there is nothing new or unfamiliar there. The prompts I'm getting are the standard New Hardware Found prompts from Windows. They pop up as if I'd installed a new component to the computer or a new printer on the network, but I haven't. This device is supposed to be like just another computer on the network that Vista needs to communicate with.
    AMD
    ASUS M3A78-EM
Ex_Brit
I'm not familiar with WDC Cloud drives, only their physical ones, but I do see at their website under Support and Downloads several items listed including a firmware update dated May this year. Have you installed all that already?
It might better serve you to ask Western Digital support what's wrong.
    Win 10 Pro x64 x 2
    Alienware ALX x58
    2 x 500gb SATA II
    1 x 1TB SATA II
    (Non-RAID)
    Unique
    1gb/s up and down
AndyTampa
This is a physical drive, but it's called the MyCloud because I can access it from anywhere. It's a personal cloud instead of giving all my files to ASUS or Google or Microsoft, etc. It is really a Network Attached Storage (NAS) device.
Yes, I have the latest firmware. The device is supposed to work without the other downloads. The only one needed is the setup software, though I don't know what it actually sets up or how to UN-set it up. I can no longer roll back unless I chance a disk restore. And even with that, I'm not sure how far back to go.
Customer support at WD is minimal. They assume any incompatibility problems are not theirs and aren't concerned about customer satisfaction. I've already had this too long to return it.
    AMD
    ASUS M3A78-EM
Ex_Brit
Yes I know WD themselves aren't too helpful except to provide usually what you already know about and I just mentioned. What about their forums?
Home - WD Community
    Win 10 Pro x64 x 2
    Alienware ALX x58
    2 x 500gb SATA II
    1 x 1TB SATA II
    (Non-RAID)
    Unique
    1gb/s up and down
AndyTampa
Forums?! I didn't realize they had forums. Wait. Yes I did.
I did Google searches that brought me to their pages, where they said to call Microsoft or that the person's problem sounds like an operating system problem. They didn't offer any actual help.
    AMD
    ASUS M3A78-EM
Ex_Brit
I was hoping someone there may have seen the same issue.
    Win 10 Pro x64 x 2
    Alienware ALX x58
    2 x 500gb SATA II
    1 x 1TB SATA II
    (Non-RAID)
    Unique
    1gb/s up and down
AndyTampa
Oh, some have seen the same issue, but WD's response is that since it is a separate piece of hardware and no software is needed, then it had to be a problem that was already on the user's system. They've seen this issue on their internal hard drives too. They build those so that Windows uses it's built-in drivers.
    AMD
    ASUS M3A78-EM
Ex_Brit
    Win 10 Pro x64 x 2
    Alienware ALX x58
    2 x 500gb SATA II
    1 x 1TB SATA II
    (Non-RAID)
    Unique
    1gb/s up and down
AndyTampa
OK, obviously they're useless. I'm assuming this is Vista SP2 and fully updated. Have you asked Vista to search within itself to locate the driver?
http://www.vistax64.com/tutorials/193584-device-manager-install-driver.html
The link tells me how to install a drive, but not how to make Vista search inside itself. I don't know where it should be searching.
I've seen posts where it is mentioned that these types of drives should be listed under NAS Devices, but when I tried to Add Hardware, that wasn't a choice.
    AMD
    ASUS M3A78-EM
Ex_Brit
I'm afraid I have no idea what to do then. I assume you posted in their forums, try it again maybe?
    Win 10 Pro x64 x 2
    Alienware ALX x58
    2 x 500gb SATA II
    1 x 1TB SATA II
    (Non-RAID)
    Unique
    1gb/s up and down
AndyTampa
Thank you, Peter, for all your assistance. You're one of the few people and this is one of the very few forums where I can get helpful ideas and advice that I hadn't already known or thought of.
    AMD
    ASUS M3A78-EM
Ex_Brit
You're welcome, I only wish I had some better ideas on this particular one.
    Win 10 Pro x64 x 2
    Alienware ALX x58
    2 x 500gb SATA II
    1 x 1TB SATA II
    (Non-RAID)
    Unique
    1gb/s up and down
AndyTampa
I have no idea how, but one day it just started working. I don't know how, but this issue is resolved.
    AMD
    ASUS M3A78-EM
Ex_Brit
Windows works in very mysterious ways - well at least that sound good.
Glad it's sorted.
    Win 10 Pro x64 x 2
    Alienware ALX x58
    2 x 500gb SATA II
    1 x 1TB SATA II
    (Non-RAID)
    Unique
    1gb/s up and down
