Vista problem
ivan-hrv
Hello!!
I have problem with booting vista. When I turn on my "lenovo 3000 n 100" all i can see is lenovo start screen that usually lasts for few seconds and then show goes on...but now..lenovo start screen is not moving...it seems like lptop stopped working...
I found way to turn on lptop by pressing "delete" bottun when lenovo start screen appears and choosing F1 to go to BIOS and "Exit discarding changes". Then lptop normally works...but i do nothing...just "exit discarding changes"
Can anyone tell me how to start normally my lptop?
Hi Ivan and welcome to the forums :party:
Does your laptop keep the correct time in your BIOS? This sounds as though the battery is failing or has failed and that the settings are being corrupted. Have a look at the following forum to see if anyone can help you. If necessary post your question there and see what results you get. Please post back here with the response so that others benefit.
lenovo community - lenovo community
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Gigabyte IF233
How old is your laptop?
Does this happen when just using battery power or also when connected to the mains?
    I5 3570K
    Gigabyte Z77-DS3H
    Gigabyte Geforce GTX 660 TI
    creative x-fi
    Both 1680 x 1050
    Technika TKOPTM2
    Logik
Is there disk access (is the light blinking) or is the computer totally froze?
Has this started to happen after an update?
Will the computer start in safe mode?
Have you flashed your bios? (I dont want you to if you have not, it is just a question)
    I5 3570K
    Gigabyte Z77-DS3H
    creative x-fi
    Both 1680 x 1050
    Technika TKOPTM2
    Logik
light is not blinking, cannot start from safe mode..
it happened after low battery , lptop went to sleep i guess and didn't want to start after
    Gigabyte IF233
That didn't help neither.
Today i had another problem, lptop couldn't start bios utility. So friend gave me idea to remove bios battery if it's bios problem. So i did and lptop turned on but same problem remains. in order to turn on windows i have to hit exit discarding changes in bios utility.
I 've almost forgot how it is to turn on lptop by pressing just one button, not whole scrypt of buttons?
Someone help please!?
I am afraid that you will have to reinstall your Vista application from scratch. I had more or less the same problem with a Lenovo N100 3000. First the battery failed and then i had what you described above.
What helped was a clean install.
You should be loading a 32bit on your Lenovo N100 3000 it cannot sustain x64!!!!
    Acer Aspire 5920gmi notebook
    NVIDIA GeForce 8600M GS
    Realtek
    crawl
Today i went out of battery and lptop went to hibernation i guess.
After plugging power cable in again same problem, can't start, can't go to bios utility . So i removed bios battery again and now i can turn on by choosing discard all changes in bios utility.
So i must not went out of battery or i 'll have to remove bios battery again...after two times it's getting bored.
Someone help ?!
Time to call in a specialist as you have a bigger problem than software.. I would suggest that you take your laptop to a recommended windows specialist, or to the store where you bought it...
Good luck!
    Realtek
    crawl
Well one thing i did not mention... i had vista home premium and there were no problems, after that i got vista ultimate and that's where problems started!
