Vista SP1 RAM problem !!
Nermin
Hi guys I got Vista SP1 32bit and I have a strange problem..actually I have 4GB 1066 RAM...now my Vista doesnt wanna show 4GB it shows 3GB...I dont know where is the problem..I need to fix this so if you know please reply...thanks for any help.
    Intel Core2Duo E8400 3Ghz
    Abit Quad GT
    nVIDIA POV GF9600GT 1GB
Hi Nermin....... welcome to the vista forum ;)
the problem you have is the 32bit OS, by default a 32bit OS has only 4gb available address space, this includes your VRAM (RAM attached to your GFX card) & other BIOS functions...
there is no way round this...... you will only EVER be able to utilize about 3-3.2gb, in order to utilize the full 4gb + you will need to migrate to a 64bit OS...
:)SK
    ME.....
    Q9450 @ 3.6ghz
    P5K PREMIUM
    8GB 1066mhz buffalo firestix
    HD 5970
    20'' syncmaster
    XCILIO 850w
    unknown ATX
    Arctic cooler pro 775
    logitech cordless optical
    logitech EX110
    2mb
I concur with skunksmash's assesment.
Even if you did have a full 4GB installed, depending on your motherboard, you will only be able to access between 3.0GB and 3.4GB. The "lost" memory is mapped to motherboard devices (either onboard or via expansion slots) during POST when you turn on your computer.
Because this all happens on the hardware level, even a 64-Bit OS will have this restriction. But then again, you shouldn't be running a 64-Bit OS on a motherboard that does not support memory remapping.!
Unless you motherboard supports memory-remapping, to allow that "lost" ram to be used by the system, the is nothing you can do about it.
    AMD Phenom 9600 Quad
    ASUS MB-M3A32-MVP Deluxe/WiFi
    2 x A-Data 2GB DDR2-800
    ASUS ATI Radeon HD 2400PRO
    SAHARA 21"
    1600x1200
    800W
    Thermaltake Tai-Chi
    Tai-Chi Water Cooler
    Genius
    384kbps
Dude I know that but in the start it showed 4 GB Im bit worried because maybe my RAM is broken...I dont know..are u sure this is the main problem...motherboard is abit quadGT
    Abit Quad GT
    SAHARA 21"
    1600x1200
    800W
    Thermaltake Tai-Chi
    Genius
    384kbps
if you type ''msinfo'' into the search bar, then select ''system information'' this should state the amount of physical memory installed & how much is ACTUALLY available for use...
if you had a dead RAM stick your rig would not post....
:)SK
    ME.....
    Q9450 @ 3.6ghz
    P5K PREMIUM
    HD 5970
    20'' syncmaster
    XCILIO 850w
    unknown ATX
    logitech EX110
    2mb
I did that a few days ago and it didnt show any errors and in the start it was all ok but now its shows just 3 GB..rr im so mad..
    Abit Quad GT
Right. Boot into your system BIOS (usually by repeatedly pressing the <DEL> during initial power on).
What does the BIOS report as "Installed Memory" and "Usable Size". There is a distinction between the two.
If "usable" is less than "installed", then there are perhaps some settings in your BIOS that have changed from what they aught to be?
    SAHARA 21"
    1600x1200
    800W
    Thermaltake Tai-Chi
    Genius
    384kbps
Ok bro hope this would work..I will restart now....God Im sick of this :)
    Abit Quad GT
hah I couldnt find any information about ram memory :S and I run memory diagnostic tool and there are no errors...i opened my computer case and all is ok but the problem is still here ...
    Abit Quad GT
Nice machine u got there alexander :) anyway thanks for help but I will try to get vista x64 if u want i could give you my msn adress..let me know and thanks again:)
    Abit Quad GT
Guys thanks for help but I didnt suceed to fix this...nice machine u got there Alexander.. I could gave u my msn adress if u want just let me know it would be cool because you know lot about computers...thanks again and I will try to get vista x64
    Abit Quad GT
I was under the impression that both XP 32bit and Vista 32 bit could only access up to 3 gb of ram + or -???
Turn on the memory POST test so it counts memory on power up. See if all 4 GB is counted.
    16GB DDR667
    SAS RAID
I cant find any information about RAM in BIOS...my motherboard is ABIT QUAD GT
    Abit Quad GT
See my previous post in this same thread : http://www.vistax64.com/general-discussion/202298-vista-sp1-ram-problem-2.html#post932023
Using Binary Math :
2^32 = 4294967296
4294967296 / 1024 = 4194304
4194304 / 1024 = 4096
4096 / 1024 = 4
32-Bit is thus maxed out at 4GB by it's very nature. The 3GB "limit" is imposed as detailed in my previous post, and too many people often blame the OS, when in fact it is a hardware issue that occurs long before the OS is even loaded. And even then, a 32-Bit program is limited to a max of 2GB only, which is a limitation imposed by the OS, although some seriously specialist programs can request a max available memory of 3GB.
    SAHARA 21"
    1600x1200
    800W
    Thermaltake Tai-Chi
    Genius
    384kbps
3GB is a limitation for an application using the /3GB switch. Most apps use 2GB max.
    16GB DDR667
    SAS RAID
Hey Nermin...
I didn't quite understand what you mean "in the start it showed 4GB".
Since you have 4GB of RAM and a 32bit OS, the correct appearance should be like this:
When you start your computer, your POST screen should show 4GB of RAM.
When you enter windows, you should only see 3GB of RAM.
if this is the case, it's normal. You need 64bit windows to utilize ram > 3GB.
If your BIOS/POST screen shows 3GB, then indeed you have lost 1GB of RAM.
    Limneos
    Intel Core2Duo E4500 2.2GHz
    Asus P5LD2-X/1333
    2GB 800Mhz Kingston DDR2
    Nvidia 8500GT
I want to say that when I installed Vista SP1 x32 first time in the "My Computer>Properties" it showed 4 GB RAM now its only 3 GB...is this problem with my system or with my memory...let me know but I want to be 100% sure that my RAM isnt dead...
    Abit Quad GT
My post screen appears to fast so I cant see how much memory does it show
    Abit Quad GT
