vista start up problems
otter
This is the original OS installed on the machine. I made recovery disks and recently used them to do a clean install. This system is about 2 years old and until recently, I haven't had any problems. When the problems started, it seemed to escalate. I've attached the performance reports. I noticed that it reported about drive D, I disconnected that when I re-installed vista and haven't plugged it back in yet. I thought it was odd that it reported on a drive that wasn't plugged in. If you need anything else, please let me know.
Thanks for your help.
    HP-Pavilion GX611AAR-ABA m8300f
    AMD Athlon 64x2 Dual Core
    ECS Nettle2 (socket AM2)
    3 GB Dual Channel DDR2 @ 334 MHz
    GeForce 6150SE nForce 430
    HP L1710
    ST332082 0AS SCSI Disk Device, 313 GB
    3 fans
    PS/2
    HP KB0911
    5 GB down, .5 upload
Welcome
About 10 reports with about 6 different results.
4e be c5 1a 7e 8e
Code:
 crosoft (R) Windows Debugger Version 6.11.0001.404 AMD64
Loading Dump File [C:\Users\richc46\AppData\Local\Temp\Temp9_Windows_NT6_BSOD_jcgriff2[1].zip\Windows_NT6_BSOD_jcgriff2\Mini121510-02.dmp]
Symbol search path is: SRV*c:\symbols*http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows Server 2008/Windows Vista Kernel Version 6002 (Service Pack 2) MP (2 procs) Free x86 compatible
Built by: 6002.18267.x86fre.vistasp2_gdr.100608-0458
Machine Name:
Kernel base = 0x81e04000 PsLoadedModuleList = 0x81f1bc70
Debug session time: Wed Dec 15 17:31:00.223 2010 (GMT-5)
System Uptime: 0 days 11:42:13.924
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
Unable to load image \SystemRoot\system32\drivers\HCW85BDA.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for HCW85BDA.sys
*** ERROR: Module load completed but symbols could not be loaded for HCW85BDA.sys
1: kd> !analyze -v
SYSTEM_THREAD_EXCEPTION_NOT_HANDLED_M (1000007e)
This is a very common bugcheck.  Usually the exception address pinpoints
the driver/function that caused the problem.  Always note this address
as well as the link date of the driver/image that contains this address.
Some common problems are exception code 0x80000003.  This means a hard
coded breakpoint or assertion was hit, but this system was booted
/NODEBUG.  This is not supposed to happen as developers should never have
hardcoded breakpoints in retail code, but ...
If this happens, make sure a debugger gets connected, and the
system is booted /DEBUG.  This will let us see why this breakpoint is
happening.
Arguments:
Arg1: 80000003, The exception code that was not handled
Arg2: 8e445010, The address that the exception occurred at
Arg3: 8ad84bfc, Exception Record Address
Arg4: 8ad848f8, Context Record Address
Debugging Details:
EXCEPTION_CODE: (HRESULT) 0x80000003 (2147483651) - One or more arguments are invalid
FAULTING_IP:
HCW85BDA+3d010
8e445010 cc              int     3
EXCEPTION_RECORD:  8ad84bfc -- (.exr 0xffffffff8ad84bfc)
ExceptionAddress: 8e445010 (HCW85BDA+0x0003d010)
   ExceptionCode: 80000003 (Break instruction exception)
  ExceptionFlags: 00000000
NumberParameters: 3
   Parameter[0]: 00000000
   Parameter[1]: 873e7558
   Parameter[2]: 8f310020
CONTEXT:  8ad848f8 -- (.cxr 0xffffffff8ad848f8)
eax=00005000 ebx=00000000 ecx=87700000 edx=8f310020 esi=873e7558 edi=00000000
eip=8e445010 esp=8ad84cc4 ebp=8ad84cdc iopl=0         nv up ei ng nz na po nc
cs=0008  ss=0010  ds=0023  es=0023  fs=0030  gs=0000             efl=00000282
HCW85BDA+0x3d010:
8e445010 cc              int     3
Resetting default scope
CUSTOMER_CRASH_COUNT:  2
DEFAULT_BUCKET_ID:  VISTA_DRIVER_FAULT
BUGCHECK_STR:  0x7E
PROCESS_NAME:  System
CURRENT_IRQL:  0
ERROR_CODE: (NTSTATUS) 0x80000003 - {EXCEPTION}  Breakpoint  A breakpoint has been reached.
EXCEPTION_PARAMETER1:  00000000
EXCEPTION_PARAMETER2:  873e7558
EXCEPTION_PARAMETER3:  8f310020
LAST_CONTROL_TRANSFER:  from 8e43a8b2 to 8e445010
STACK_TEXT:
WARNING: Stack unwind information not available. Following frames may be wrong.
8ad84cdc 8e43a8b2 00000044 873e7558 87700000 HCW85BDA+0x3d010
8ad84d00 8e439ea1 8ad84d14 87700000 00000000 HCW85BDA+0x328b2
8ad84d64 8e43ab9c 87700000 00d84d80 8ad84d7c HCW85BDA+0x31ea1
8ad84d74 8e43acfd 8ad84dc0 81fd9c42 87700000 HCW85BDA+0x32b9c
8ad84d7c 81fd9c42 87700000 5a49468e 00000000 HCW85BDA+0x32cfd
8ad84dc0 81e42f4e 8e43acf0 87700000 00000000 nt!PspSystemThreadStartup+0x9d
00000000 00000000 00000000 00000000 00000000 nt!KiThreadStartup+0x16
FOLLOWUP_IP:
HCW85BDA+3d010
8e445010 cc              int     3
SYMBOL_STACK_INDEX:  0
SYMBOL_NAME:  HCW85BDA+3d010
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: HCW85BDA
IMAGE_NAME:  HCW85BDA.sys
DEBUG_FLR_IMAGE_TIMESTAMP:  4a5cee24
STACK_COMMAND:  .cxr 0xffffffff8ad848f8 ; kb
FAILURE_BUCKET_ID:  0x7E_HCW85BDA+3d010
Followup: MachineOwner
1: kd> lmtsmn
start    end        module name
8e0d9000 8e0e6080   1394BUS  1394BUS.SYS  Sat Jan 19 00:53:27 2008 (47919057)
80604000 8064a000   acpi     acpi.sys     Sat Apr 11 00:19:03 2009 (49E01A37)
8e174000 8e1bc000   afd      afd.sys      Sat Apr 11 00:47:01 2009 (49E020C5)
89d2b000 89d3b000   amdk8    amdk8.sys    Sat Jan 19 00:27:20 2008 (47918A38)
8070f000 80717000   atapi    atapi.sys    Sat Apr 11 00:39:09 2009 (49E01EED)
80717000 80735000   ataport  ataport.SYS  Sat Apr 11 00:39:10 2009 (49E01EEE)
9d18d000 9d1b5000   AVGIDSDriver AVGIDSDriver.Sys Tue Aug 03 18:23:31 2010 (4C5896E3)
89fca000 89fd3000   AVGIDSEH AVGIDSEH.Sys Mon Sep 13 18:46:29 2010 (4C8EA9C5)
9d183000 9d18d000   AVGIDSFilter AVGIDSFilter.Sys Tue Aug 03 18:23:08 2010 (4C5896CC)
9d051000 9d05c000   AVGIDSShim AVGIDSShim.Sys Tue Aug 03 18:25:55 2010 (4C589773)
8df8f000 8dfca400   avgldx86 avgldx86.sys Mon Sep 06 20:48:07 2010 (4C858BC7)
8f68a000 8f696000   avgmfx86 avgmfx86.sys Mon Sep 06 20:48:01 2010 (4C858BC1)
89fc5000 89fc9b80   avgrkx86 avgrkx86.sys Mon Sep 06 20:48:16 2010 (4C858BD0)
8f746000 8f78d980   avgtdix  avgtdix.sys  Tue Nov 09 15:11:29 2010 (4CD9AAF1)
8e569000 8e56c000   BdaSup   BdaSup.SYS   Sat Jan 19 00:53:30 2008 (4791905A)
8f6a6000 8f6ad000   Beep     Beep.SYS     Sat Jan 19 00:49:10 2008 (47918F56)
80418000 80420000   BOOTVID  BOOTVID.dll  Sat Jan 19 02:27:15 2008 (4791A653)
9b744000 9b75d000   bowser   bowser.sys   Sat Jan 19 00:28:26 2008 (47918A7A)
96250000 9625e000   cdd      cdd.dll      unavailable (00000000)
9d1b5000 9d1cb000   cdfs     cdfs.sys     Sat Jan 19 00:28:02 2008 (47918A62)
8e316000 8e32e000   cdrom    cdrom.sys    Sat Apr 11 00:39:17 2009 (49E01EF5)
80461000 80541000   CI       CI.dll       Sat Apr 11 02:25:22 2009 (49E037D2)
8e376000 8e384000   circlass circlass.sys Sat Jan 19 00:53:24 2008 (47919054)
89f9b000 89fbc000   CLASSPNP CLASSPNP.SYS Sat Apr 11 00:39:05 2009 (49E01EE9)
80420000 80461000   CLFS     CLFS.SYS     Sat Apr 11 00:13:51 2009 (49E018FF)
8e200000 8e20d000   crashdmp crashdmp.sys Sat Apr 11 00:39:12 2009 (49E01EF0)
89fbc000 89fc5000   crcdisk  crcdisk.sys  Thu Nov 02 04:52:27 2006 (4549B1CB)
8df78000 8df8f000   dfsc     dfsc.sys     Sat Apr 11 00:14:12 2009 (49E01914)
89f8a000 89f9b000   disk     disk.sys     Sat Apr 11 00:39:14 2009 (49E01EF2)
8f665000 8f68a000   drmk     drmk.sys     Sat Jan 19 01:53:02 2008 (47919E4E)
8dfcb000 8dfd5000   dump_diskdump dump_diskdump.sys Sat Apr 11 00:39:11 2009 (49E01EEF)
8dfd5000 8dff2000   dump_nvstor32 dump_nvstor32.sys Fri Oct 26 14:50:16 2007 (472236E8)
8dff2000 8dffc000   Dxapi    Dxapi.sys    Sat Jan 19 00:36:12 2008 (47918C4C)
8ef5f000 8effe000   dxgkrnl  dxgkrnl.sys  Sat Apr 11 00:23:43 2009 (49E01B4F)
89f63000 89f8a000   ecache   ecache.sys   Sat Apr 11 00:40:12 2009 (49E01F2C)
8e30f000 8e315b00   ElbyCDFL ElbyCDFL.sys Thu Dec 14 16:22:33 2006 (4581C099)
8f7f7000 8f7fb200   ElbyCDIO ElbyCDIO.sys Tue Feb 17 12:11:28 2009 (499AEFC0)
807c5000 807d5000   fileinfo fileinfo.sys Sat Jan 19 00:34:27 2008 (47918BE3)
80793000 807c5000   fltmgr   fltmgr.sys   Sat Apr 11 00:13:59 2009 (49E01907)
8f696000 8f69f000   Fs_Rec   Fs_Rec.SYS   Sat Jan 19 00:27:57 2008 (47918A5D)
89cf3000 89d0e000   fwpkclnt fwpkclnt.sys Sat Apr 11 00:45:42 2009 (49E02076)
821bd000 821f0000   hal      halmacpi.dll Sat Apr 11 00:13:13 2009 (49E018D9)
8e408000 8e568700   HCW85BDA HCW85BDA.sys Tue Jul 14 16:44:20 2009 (4A5CEE24)
8e0e7000 8e174000   HDAudBus HDAudBus.sys Sat Apr 11 00:42:41 2009 (49E01FC1)
8f6b6000 8f6bc380   HIDPARSE HIDPARSE.SYS Sat Jan 19 00:53:16 2008 (4791904C)
8e007000 8e0bc000   HSX_CNXT HSX_CNXT.sys Thu May 08 16:04:13 2008 (48235CBD)
8de76000 8df78000   HSX_DP   HSX_DP.sys   Thu May 08 16:03:14 2008 (48235C82)
8de00000 8de4c000   HSXHWBS2 HSXHWBS2.sys Thu May 08 16:05:16 2008 (48235CFC)
9b6ba000 9b727000   HTTP     HTTP.sys     Sat Feb 20 15:53:31 2010 (4B804BCB)
89d3b000 89d4e000   i8042prt i8042prt.sys Sat Jan 19 00:49:17 2008 (47918F5D)
89d5e000 89d69000   kbdclass kbdclass.sys Sat Jan 19 00:49:14 2008 (47918F5A)
80400000 80407000   kdcom    kdcom.dll    Sat Apr 11 02:25:29 2009 (49E037D9)
8de4c000 8de76000   ks       ks.sys       Sat Apr 11 00:38:47 2009 (49E01ED7)
89a08000 89a79000   ksecdd   ksecdd.sys   Mon Jun 15 08:48:53 2009 (4A364335)
89ddb000 89deb000   lltdio   lltdio.sys   Sat Jan 19 00:55:03 2008 (479190B7)
89dc0000 89ddb000   luafv    luafv.sys    Sat Jan 19 00:30:35 2008 (47918AFB)
9d05c000 9d05f180   mdmxsdk  mdmxsdk.sys  Mon Jun 19 17:26:59 2006 (449716A3)
8e0bc000 8e0c9000   modem    modem.sys    Sat Jan 19 00:57:16 2008 (4791913C)
89fd3000 89fe2000   monitor  monitor.sys  Thu Nov 02 04:54:05 2006 (4549B22D)
89d4e000 89d59000   mouclass mouclass.sys Sat Jan 19 00:49:14 2008 (47918F5A)
806ff000 8070f000   mountmgr mountmgr.sys Sat Jan 19 00:49:13 2008 (47918F59)
9b75d000 9b772000   mpsdrv   mpsdrv.sys   Sat Jan 19 00:54:45 2008 (479190A5)
9b772000 9b793000   mrxdav   mrxdav.sys   Sat Apr 11 00:14:39 2009 (49E0192F)
9b793000 9b7b2000   mrxsmb   mrxsmb.sys   Tue Feb 23 06:10:12 2010 (4B83B794)
9b7b2000 9b7eb000   mrxsmb10 mrxsmb10.sys Tue Feb 23 06:10:17 2010 (4B83B799)
89d0e000 89d26000   mrxsmb20 mrxsmb20.sys Tue Feb 23 06:10:12 2010 (4B83B794)
8f6fa000 8f705000   Msfs     Msfs.SYS     Sat Jan 19 00:28:08 2008 (47918A68)
80653000 8065b000   msisadrv msisadrv.sys Sat Jan 19 00:32:51 2008 (47918B83)
8e578000 8e5a7000   msiscsi  msiscsi.sys  Sat Apr 11 00:40:07 2009 (49E01F27)
89b84000 89baf000   msrpc    msrpc.sys    Sat Apr 11 00:37:32 2009 (49E01E8C)
8e384000 8e38e000   mssmbios mssmbios.sys Sat Jan 19 00:32:55 2008 (47918B87)
89f54000 89f63000   mup      mup.sys      Sat Apr 11 00:14:12 2009 (49E01914)
89a79000 89b84000   ndis     ndis.sys     Sat Apr 11 00:45:52 2009 (49E02080)
8e5c9000 8e5d4000   ndistapi ndistapi.sys Sat Jan 19 00:56:24 2008 (47919108)
8e5d4000 8e5f7000   ndiswan  ndiswan.sys  Sat Apr 11 00:46:31 2009 (49E020A7)
8e3d0000 8e3e1000   NDProxy  NDProxy.SYS  Sat Jan 19 00:56:28 2008 (4791910C)
8f7d6000 8f7e4000   netbios  netbios.sys  Sat Jan 19 00:55:45 2008 (479190E1)
8f78e000 8f7c0000   netbt    netbt.sys    Sat Apr 11 00:45:35 2009 (49E0206F)
89baf000 89bea000   NETIO    NETIO.SYS    Sat Apr 11 00:46:21 2009 (49E0209D)
8f705000 8f713000   Npfs     Npfs.SYS     Sat Apr 11 00:14:01 2009 (49E01909)
8e3e1000 8e3eb000   nsiproxy nsiproxy.sys Sat Jan 19 00:55:50 2008 (479190E6)
81e04000 821bd000   nt       ntkrpamp.exe Tue Jun 08 10:36:44 2010 (4C0E557C)
89e03000 89f13000   Ntfs     Ntfs.sys     Sat Apr 11 00:14:34 2009 (49E0192A)
8f69f000 8f6a6000   Null     Null.SYS     Sat Jan 19 00:49:12 2008 (47918F58)
8ef5d000 8ef5e080   nvBridge nvBridge.kmd Fri Oct 30 15:40:44 2009 (4AEB413C)
8e605000 8ef5cc60   nvlddmkm nvlddmkm.sys Fri Oct 30 16:00:35 2009 (4AEB45E3)
8e20f000 8e30e600   nvmfdx32 nvmfdx32.sys Fri Aug 01 14:37:49 2008 (489357FD)
80735000 80752000   nvstor32 nvstor32.sys Fri Oct 26 14:50:16 2007 (472236E8)
8e0c9000 8e0d8300   ohci1394 ohci1394.sys Sat Apr 11 00:43:04 2009 (49E01FD8)
8f7c0000 8f7d6000   pacer    pacer.sys    Sat Apr 11 00:45:51 2009 (49E0207F)
80682000 80691000   partmgr  partmgr.sys  Sat Apr 11 00:39:19 2009 (49E01EF7)
8065b000 80682000   pci      pci.sys      Sat Apr 11 00:19:16 2009 (49E01A44)
806ea000 806f1000   pciide   pciide.sys   Sat Apr 11 00:39:10 2009 (49E01EEE)
806f1000 806ff000   PCIIDEX  PCIIDEX.SYS  Sat Apr 11 00:39:09 2009 (49E01EED)
9d060000 9d13e000   peauth   peauth.sys   Mon Oct 23 04:55:32 2006 (453C8384)
8f638000 8f665000   portcls  portcls.sys  Sat Apr 11 00:42:48 2009 (49E01FC8)
89d59000 89d5da80   PS2      PS2.sys      Mon Dec 12 20:26:59 2005 (439E2363)
80407000 80418000   PSHED    PSHED.dll    Sat Apr 11 02:25:32 2009 (49E037DC)
8f713000 8f71c000   rasacd   rasacd.sys   Sat Jan 19 00:56:31 2008 (4791910F)
8e5b2000 8e5c9000   rasl2tp  rasl2tp.sys  Sat Jan 19 00:56:33 2008 (47919111)
8e32e000 8e33d000   raspppoe raspppoe.sys Sat Apr 11 00:46:30 2009 (49E020A6)
8e33d000 8e351000   raspptp  raspptp.sys  Sat Jan 19 00:56:34 2008 (47919112)
8e351000 8e366000   rassstp  rassstp.sys  Sat Apr 11 00:46:40 2009 (49E020B0)
8e1bc000 8e1f8000   rdbss    rdbss.sys    Sat Apr 11 00:14:26 2009 (49E01922)
8f6ea000 8f6f2000   RDPCDD   RDPCDD.sys   Sat Jan 19 01:01:08 2008 (47919224)
8f6f2000 8f6fa000   rdpencdd rdpencdd.sys Sat Jan 19 01:01:09 2008 (47919225)
89deb000 89dfe000   rspndr   rspndr.sys   Sat Jan 19 00:55:03 2008 (479190B7)
8f401000 8f637300   RTKVHDA  RTKVHDA.sys  Wed Feb 11 07:38:05 2009 (4992C6AD)
9d13e000 9d148000   secdrv   secdrv.SYS   Wed Sep 13 09:18:32 2006 (45080528)
8f732000 8f746000   smb      smb.sys      Sat Apr 11 00:45:22 2009 (49E02062)
89f4c000 89f54000   spldr    spldr.sys    Thu Jun 21 20:29:17 2007 (467B17DD)
9b60a000 9b6ba000   spsys    spsys.sys    Tue Mar 10 13:10:28 2009 (49B69F04)
9d003000 9d051000   srv      srv.sys      Mon Sep 06 09:45:36 2010 (4C84F080)
807d5000 807fd000   srv2     srv2.sys     Mon Sep 06 09:45:21 2010 (4C84F071)
9b727000 9b744000   srvnet   srvnet.sys   Mon Sep 06 09:45:18 2010 (4C84F06E)
80752000 80793000   storport storport.sys Sat Apr 11 00:39:19 2009 (49E01EF7)
8effe000 8efff380   swenum   swenum.sys   Sat Jan 19 00:49:20 2008 (47918F60)
89c09000 89cf3000   tcpip    tcpip.sys    Wed Jun 16 09:45:41 2010 (4C18D585)
9d148000 9d154000   tcpipreg tcpipreg.sys Tue Dec 08 12:26:18 2009 (4B1E8C3A)
8e5a7000 8e5b2000   TDI      TDI.SYS      Sat Jan 19 00:57:10 2008 (47919136)
8f71c000 8f732000   tdx      tdx.sys      Sat Apr 11 00:45:56 2009 (49E02084)
8e366000 8e376000   termdd   termdd.sys   Sat Apr 11 00:51:14 2009 (49E021C2)
96230000 96239000   TSDDD    TSDDD.dll    unavailable (00000000)
89ff5000 89ffe000   tunmp    tunmp.sys    Sat Jan 19 00:55:40 2008 (479190DC)
89fea000 89ff5000   tunnel   tunnel.sys   Thu Feb 18 06:28:13 2010 (4B7D244D)
8e38e000 8e39b000   umbus    umbus.sys    Sat Jan 19 00:53:40 2008 (47919064)
8f7fc000 8f7fd700   USBD     USBD.SYS     Sat Jan 19 00:53:17 2008 (4791904D)
89db1000 89dc0000   usbehci  usbehci.sys  Sat Apr 11 00:42:52 2009 (49E01FCC)
8e39b000 8e3d0000   usbhub   usbhub.sys   Sat Apr 11 00:43:14 2009 (49E01FE2)
89d69000 89d73000   usbohci  usbohci.sys  Sat Apr 11 00:42:52 2009 (49E01FCC)
89d73000 89db1000   USBPORT  USBPORT.SYS  Sat Apr 11 00:42:55 2009 (49E01FCF)
8e3eb000 8e400000   USBSTOR  USBSTOR.SYS  Sat Apr 11 00:42:55 2009 (49E01FCF)
8f6bd000 8f6c9000   vga      vga.sys      Sat Jan 19 00:52:06 2008 (47919006)
8f6c9000 8f6ea000   VIDEOPRT VIDEOPRT.SYS Sat Jan 19 00:52:10 2008 (4791900A)
80691000 806a0000   volmgr   volmgr.sys   Sat Jan 19 00:49:51 2008 (47918F7F)
806a0000 806ea000   volmgrx  volmgrx.sys  Sat Apr 11 00:39:25 2009 (49E01EFD)
89f13000 89f4c000   volsnap  volsnap.sys  Sat Apr 11 00:39:37 2009 (49E01F09)
8f7e4000 8f7f7000   wanarp   wanarp.sys   Sat Jan 19 00:56:31 2008 (4791910F)
8e56c000 8e578000   watchdog watchdog.sys Sat Apr 11 00:22:43 2009 (49E01B13)
80541000 805bd000   Wdf01000 Wdf01000.sys Sat Jan 19 00:52:21 2008 (47919015)
805bd000 805ca000   WDFLDR   WDFLDR.SYS   Sat Jan 19 00:52:19 2008 (47919013)
96010000 96213000   win32k   win32k.sys   unavailable (00000000)
8064a000 80653000   WMILIB   WMILIB.SYS   Sat Jan 19 00:53:08 2008 (47919044)
9d171000 9d183000   WUDFPf   WUDFPf.sys   Sat Jan 19 00:52:49 2008 (47919031)
9d15c000 9d170580   WUDFRd   WUDFRd.sys   Sat Jan 19 00:53:04 2008 (47919040)
9d154000 9d15c000   xaudio   xaudio.sys   Thu Oct 18 18:36:53 2007 (4717E005)
Outdated Drivers
Code:
xaudio.sys   Thu Oct 18 18:36:53 2007 (4717E005)W
With different causes it is probably hardware, memory most likely. Do the follwing and then post any additional BSODs after your have followed directions
Remove AVG and replace with Microsoft Security Essentials and Malwarebytes (free edition)
The reports that you have submitted reveal clues to the cause of your problem. They do not give a definitive answer. The more reports that we receive the more clues are made available improving our chances of finding a solution to your problem. You may have to experience several more BSODs until the final answer is discovered.
If overclocking restore normal settings
SFC /scannow
System Files - SFC Command
Download memtest86 and test RAM
www.sevenforums.com/tutorials/105647-ram-test-memtest86.html
Run for 8 passes
If passes try a good stick in each slot for 3 passes
If fails do the same for 8 passes.
Scan with your Anti Virus
Update outdated listed drivers. If I have inadvertently listed any Microsoft Drivers, they can be ignored.
How to Find Drivers
search Google for the name of the driver
- compare the Google results with what's installed on your system to figure out which device/program it belongs to
- visit the web site of the manufacturer of the hardware/program to get the latest drivers (DON'T use Windows Update or the Update driver function of Device Manager).
- if there are difficulties in locating them, post back with questions and someone - will help you search Google for the name of the driver
- - if there are difficulties in locating them, post back with questions and someone will try and help you locate the appropriate program.
- The most common drivers are listed on this page: http://www.carrona.org/dvrref.html
- - Driver manufacturer links are on this page: http://www.carrona.org/drvrdown.html
and here
http://www.edbott.com/weblog/the-vista-master-driver-list/
To remove any left over driver remnants, especially from graphics cards, use driver sweeper
www.guru3d.com/category/driversweeper/
You can also locate information about your driver using this information
http://www.sevenforums.com/tutorials/96442-device-manager-finding-unknown-devices.html
Uninstall your current Anti Virus and replace with Microsoft Security Essentials.
www.microsoft.com/Security_Essentials/
I removed AVG, installed and ran MSE and Malwarebytes. I've also ran a new performance scan and BSOD scan again and attached the latest results.
    HP L1710
    3 fans
    PS/2
    HP KB0911
There are no new reports in the files that you submitted
You must complete all the suggestions before submitting new reports
I'm having the worst time trying to get memtest86 to run. I've tried to do it by the instructions but am unsuccessful. I need help with this please.
Thanks
    HP L1710
    3 fans
    PS/2
    HP KB0911
Rather than have questions going back and forth concerning memtest, Ill give you the unofficial version of the instructions.
Guide to using Memtest86+
Okay, I've ran through all the steps described in the post 3 days ago to check memory as well as changing virus protection, etc. Regarding the memory, all the testing passed without any failures. Even after everything I did, the machine with still shut down by itself randomly and when I go to start the machine from being shut off over night it usually takes at least two times of re-starting to get to the desktop.
    HP L1710
    3 fans
    PS/2
    HP KB0911
Submit the new BSOD reports
Here's the latest reports.
Thanks
    HP L1710
    3 fans
    PS/2
    HP KB0911
The reports are about the same; no change.
The tests that remain to be done are the driver verifier and hardware tests. Lets start with the easy ones. Try the Driver verifier, that seems like a likely candidiate based upon the reports. Read the warnings and directions carefully.
Driver Verifier Inst
Since the driver that crashed you has not been listed you should run driver verifier
Please run Verifier with these settings:
Using Driver Verifier is an iffy proposition. Most times it'll crash and it'll tell you what the driver is. But sometimes it'll crash and won't tell you the driver. Other times it'll crash before you can log in to Windows. If you can't get to Safe Mode, then you'll have to resort to offline editing of the registry to disable Driver Verifier.
So, I'd suggest that you first backup your stuff and then make sure you've got access to another computer so you can contact us if problems arise. Then make a System Restore point (so you can restore the system using the Vista/Windows 7 Startup Repair feature).
Then, here's the procedure:
- Go to Start and type in "verifier" (without the quotes) and press Enter
- Select "Create custom settings (for code developers)" and click "Next"
- Select "Select individual settings from a full list" and click "Next"
- Select everything EXCEPT FOR "Low Resource Simulation" and click "Next"
NOTE: You can use Low Resource Simulation if you'd like. From my limited experimentation it makes the BSOD's come faster.
- Select "Select driver names from a list" and click "Next"
Then select all drivers NOT provided by Microsoft and click "Next"
- Select "Finish" on the next page.
Reboot the system and wait for it to crash to the Blue Screen. Continue to use your system normally, and if you know what causes the crash, do that repeatedly. The objective here is to get the system to crash because Driver Verifier is stressing the drivers out. If it doesn't crash for you, then let it run for at least 36 hours of continuous operation (an estimate on my part).
Reboot into Windows (after the crash) and turn off Driver Verifier by going back in and selecting "Delete existing settings" on the first page, then locate and zip up the memory dump file and upload it with your next post.
If you can't get into Windows because it crashes too soon, try it in Safe Mode.
If you can't get into Safe Mode, try using System Restore from your installation DVD to set the system back to the previous restore point that you created.
Enable the driver verifier
www.sevenforums.com/crash-lockup-debug-how/65331-using-driver-verifier-identify-issues-drivers.html
OK then what do you suggest? There is a possiblity that the problem is caused by drivers; so we have to test them. I have given you the possible problems that may arise due to the test. The decision on what to do is up to you.
