Vista Startup Problem
mestan07
Posted in wrong palce, sorry!!!
Hi, new here, and didn't know where to put this, but here goes (sorry long):
I dl'd Mozilla Firefox a day ago, and everything dl'd correctly and completely. But, when I shut down the cpu, it wouldn't start up at all.
I did every diagnostic i could let the cpu do, ran a system restore (went all the way back to 10/25/09 restore point). then, i got it to run in safe mode. played with start-up options, and got the desktop to come up in normal mode, but then got error msg 0x800106ba (windows defender won't load), this meant that none of my security stuff loaded either. i ran a chkdisc thing too, and it stopped when looking through file data (stopped at 16%).
thus, i am running the cpu in safe mode with networking, and the cpu is running fine.
i know this means that there is a file issue. but i am not sure how to find it.
please help.
thanks
    HP Pavillion DV9700
    Self Build
    Asus P5Q Premium
    2 x ASUS EAH 4870 X 2 (Quad)
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
    HP Pavillion DV9700
If you don't have a DVD/CD, do you have a back up on another HDD or on your HDD on another partition ?.
Just check, you may have to use it, and if you do, you may lose all your data.
What make and model is you PC ?.
    Self Build
    Asus P5Q Premium
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
Sorry, it's a Hard Drive.
If you never had disk with it, there must be some sort of recovery partition, at least i would think there was.
    Self Build
    Asus P5Q Premium
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
