Hello all,
I am having problems with 32-bit Vista booting on my laptop. I'm guessing my start up files are shot but I'm not sure.
I turned it on after a it was off for a while and it booted OK. I left it on and it automatically rebooted itself. It started going into Start Up Repair and would cycle through that a few times and then stop. System just shows a blank screen. I was able to turn it off from there. Turning it back on would repeat the same process. I tried last good config and got to my login but from there I got a blue screen and the startup repair would cycle again. Start Up Repair does not seem to fix the problem. It just cycles till it gives up. I can get into Safe Mode if that's any help.
The laptop is an HP that came with Vista pre-installed and all I have is their recovery disk.
UPDATE!!!: My laptop was sitting in Safe Mode as I was writing this. I just got up to check it and it was sitting at the normal login screen(not safe mode). I logged in and now I'm told that I need to activate my copy of Vista. There is a little message on the bottom right saying that my copy is invalid. Funny, I used this laptop for 2 years when I worked on the road with no issues.
Now I'm pulling my hair out!!!
