Vista will not load
pudclarke
Hello all,
My parents laptop has gone wrong and I am rather stuck on trying to get it up and running again.
When the laptop is switched on, I get a screen saying Windows failed to start. I am given various boot options (safe mode, last known good configuration, start Windows normally etc). Whichever option I choose I then get another message saying to insert the installation disc which they don't have. I bought a recovery disc from eBay but when I run this , I get the following message
'windows could not start because the following file is missing or corrupt:
<Windows root>\system32\hal.dll
Please re-install a copy of the above file.
I assume I can download a copy of this file from the web but I don't have a clue how to install it because Windows won't start.
Any advice would be greatly appreciated as its my parents laptop and they have so much stuff on it and really need to get it back up and running
many thanks
Do you have a Vista install DVD you can use to attempt repairs? If not, post post here:
Vista ISO download
and ask Peter (Ex_Brit) to send you the link to the versions of Vista you need, 32 or 64. Include your E-mail address mucked up, like abc at xyz DOT com then edit your post and remove it as soon as you receive the link.
The ISO Peter provides has both SP1 and SP2 applied.
Create a DVD from the ISO using ImgBurn.
Boot the DVD, click on Repair your computer on the 2nd screen (I think).
From Command Prompt, run chkdsk c: /f.
See if that resolves the problem.
    Windows 10 Pro X64
    Lenovo IdeaCenter K450
    Intel(R) Core(TM) i7-4770 CPU @ 3.40GHz, 3401 Mhz, 4 Core(s)
    16GB
    NVIDIA GeForce GTX 750, Intel(R) HD Graphics 4600
    Samsung 27" C27F398 Curved Monitor
    1920 x 1080 (HDMI)
    Samsung SSD 840 EVO 250GB Seagate ST2000NM001 2TB Seagate ST31500341AS 1.5TB
    500W
    Lenovo USB
    50MB Down, 10MB Up
    Windows 7 Pro X64
    HP xw4400 Workstation
    Intel Pentium D Dual 3.4Ghz
    HP 0A68h
    5GB
    Realtek HD Audio
    Acer KN242HYL 24" (KVMS)
    1920X1080
    Seagate ST3120026As 120GB SATA (boot) Toshiba DT01ACA200 2TB SATA
    Logitech via KVMS switch
    Dell USB via KVMS switch
    50 Down, 10 Up
    Apache Web Server since 2001
That is a bad message to get due to what that file does. The only solution is to reinstall windows because either Windows is corrupt or the hard drive is corrupt. I recommend that you download the ISO as per ztucker's link and reinstall. As for downloading a copy on the web, NEVER do that. It could be infected or hacked and replacing it might not even solve the problem. If you need to get their data off use a bootable copy of linux such as ubuntu or knoppix.
    Windows 7 Pro & 10 Pro
    HP Pavillion Elite HPE-250f
    8 gb
    ATI Radeon HD 5770 1 gb ram
    Alienware 25 AW2521HF
    1920x1080 &1680x1050
    1 TB & 500 GB
    Lenovo Thinkpad T400
    LENOVO 64734VM
    Conexant 20561 SmartAudio HD
    15 inch
    Medium for New Zealand
