I am in desperate need of some advice and if anyone can help me I would really be grateful.
I am running Vista 32bit Home Premium on a Dell Inspiron E1705 laptop.
I shut my computer off last night as I normally do before I went to bed. It shut down without any issues. Everything was the same as it normally is.
When I went to turn on my computer today, it goes through the Dell startup screen, then it tells me there might be a problem with some hardware or something to that effect and gives me the option to either “Launch Startup Repair” or “Start Window Normally”, then windows attempts to start (has the green scrolling bar at the bottom). Either of these options take me to the same place next which is a screen that states “System Recovery Options”, and asks me to select my keyboard language. So I did and hit “next” to continue to a screen that asks me to sign into my account on the computer, and then it took me to another page that displayed a box of system recovery tools.
Being a little confused about what was happening, I selected the option for “Startup Repair”. When it finished I chose to restart the computer as it noted that if the problem was fixed it would start normally. It didn’t start normally and I went through the same process again when it rebooted. I have tried this option many times today, and it isn’t working.
I also have tried a few times the option for “Windows Memory Diagnostic Tool”. It goes trough the tests, says nothing about finding a problem, then the computer restarts to the same situation.
I have tried many different options, including starting in all the Safe Modes, starting in different screen resolutions, starting from the last known good configuration point, system repair, start windows normally, etc. It takes me back to the same screen every time.
I have tried to use the option for “System Restore”, which stated that it could not find a previous restore point, when I am almost certain that I have created on in the past.
I tried the option to go to the command prompt, where I tried a few commands. The first command was “sfc /scannow”. The response was something to the effect of the command could not run because another repair attempt was already in progress. The second command was “Bootrec.exe /fixMBR”, with the response being it had completed successfully. The third command was “Bootrec.exe /fixBoot”, again with the response being that it had completed successfully. None of this has worked, as it still takes me to the system recovery options upon turning the computer on.
I got the installation DVD out, booted from the dvd, and tried to repair it that way. It gives basically the same options as I tried before, but I went through them again anyway, and still have the same problem.
I used the F12 key to get into the boot menu, and used the “Diagnostics” option. This automatically started a “PSA+ Pre-Boot System Assessment”, and everything checked out. I ran a memory test on the computer from this same option, and all the tests passed. I will be running the extended hardware test overnight tonight. It also seems like I have tried a few more options throughout the day but these are the ones I can remember for sure.
I took down some information after some of the tests I ran and will post it at the bottom hoping to shed some light on the problem I having. But right now I am lost on what to try next. It has been a while since I have backed up my information to my external hard drive, and there is a lot of stuff on this computer that would be devastating to lose.
I don’t mind the idea of a fresh install or wiping the system clean if that is what it needs, if I can get my files off the computer before that happens. Does anyone know of anyway to retrieve these files? Is it even possible?
Any help anyone can give would be much appreciated. I have looked online for answers but all the suggestions have been a dead end for me. The computer starts to come on, starts to boot, but then goes to this same screen about system recovery options every time. I can not recall anything that I would have download the last time the computer was on or anything that I have done different than normal from other times over the 2-3 years I have had this computer. It just out of the blue did this today.
Thanks!!! The results of some of the tests are below. From what I can tell, the problem may be with either of these files:
Boot Critical File C:\windows\system32\drivers\wdf01000.sys is corrupt
Boot critical file C:\wdfldr.sys is corrupt
TEST RESULTS:
I do not remember which test this was exactly, maybe the “PSA+ Pre-Boot System Assessment”?
Problem Signature:
Problem Event Name: StartupRepairV2
Problem Signature 01: SystemDisk
Problem Signature 02: 6.0.6000.16386.6.0.6001.18000
Problem Signature 03: 6
Problem Signature 04: 393225
Problem Signature 05: Corrupt Volume
Problem Signature 06: NoRootCause
Problem Signature 07: 0
Problem Signature 08: 2
Problem Signature 09: WrpRepair
Problem Signature 10: 0
OS Version: 6.0.6000.2.0.0.256.1
Locale ID: 1033
This was a result from the System Repair Test:
Startup Repair Diagnosis and Repair Log
Last Successful Boot Time: 7/9/2009 11:27:31 AM (GMT)
Number of repair attempts: 7
Session Details:
System Disk = \Device\Harddisk0
Windows Directory = C:\Windows
Autochk Run = 0
Number of Root Causes = 1
(then is lists a bunch of different tests it ran that were completed successfully….I didn’t write each test down)
Root Cause Found:
Boot Status Indicates That The OS booted successfully
Session Details:
Autochk Run = 0
Number of Root Causes = 2
Root Cause Found:
Boot critical file C:\Windows\System32\drivers\Wdf01000.sys is corrupt
Root Cause Found:
Boot critical file C:\WDFLDR.SYS is corrupt
Session Details:
Autochk Run = 0
Root Cause Found:
Boot critical file C:\windows\system32\drivers\wdf01000.sys is corrupt
Repair Action: File Repair
Result: Completed Successfully. Error Code = 0x0
Time Taken = 8673ms
Root Cause Found:
Result: Failed. Error Code = 0x2
Time Taken = 7722ms
Repair Action: System files integrity check and repair
Time Taken = 676920ms
TEST RESULTS:
Problem Signature:
Locale ID: 1033
Session Details:
Autochk Run = 0
Root Cause Found:
Session Details:
Autochk Run = 0
Root Cause Found:
Root Cause Found:
Session Details:
Autochk Run = 0
Root Cause Found:
Time Taken = 8673ms
Root Cause Found:
Time Taken = 7722ms
all i can offer is............
