You should upgrade or use an
alternative browser .
Volume meter in Sound Properties
Hi guys,
Today I noticed that the little volume meter next to each device under "Recording Devices" (Right-click your little speaker in the task bar and select Recording Devices) has disappeared. I know it disappeared either today or yesterday. I haven't done anything that could have messed with it. Do you guys know how I can get it back?
Thanks
E6750 @ 3.2GHz
Asus P5K-e/Wifi-AP
4x1GB Crucial Ballistix DDR2 800
PNY 8800GT @ 675/1675/950
Asus Xonar DX
Samsung SyncMaster 220WM
500GB WD SATA II
500GB Seagate SATA II
700W OCZ GameXStream
Cooler Master Centurion 5
Arctic Cooling Freezer 7 Pro
Logitech G5
~3Mb
Hi Spd2Last,
You might try reinstalling your audio driver to see if that fix it.
Operating System
1TB Samsung 990 PRO M.2,
4TB Samsung 990 PRO PRO M.2,
TerraMaster F8 SSD Plus NAS
Galaxy S23 Plus phone
Operating System
Thanks for your reply,
I followed your advice but that didn't fix anything. Is there a registry setting that you may know of for this?
E6750 @ 3.2GHz
Asus P5K-e/Wifi-AP
Asus Xonar DX
500GB WD SATA II
Logitech G5
~3Mb
Well Spd2Last,
The next thing to try is to do a System Restore using a restore point dated before this problem happened to hopefully fix the problem.
Operating System
Operating System
I've never had any faith at all in System Restore as it had never worked for me in any flavor of XP, but Vista's 2 for 2 now. It worked, but I would love to know what it was that happened to have taken away my meters. Thank you again for the help.
E6750 @ 3.2GHz
Asus P5K-e/Wifi-AP
Asus Xonar DX
500GB WD SATA II
Logitech G5
~3Mb
Your welcome Spd3Last. I'm glad to hear that your problem is fixed now. It could have been a corrupted file somewhere that caused it. ??
Operating System
Operating System
