Volume Mixer
Ardaos
Hey, I muted a program using the Volume Mixer(the speaker icon next to the time), but now I cant unmute it because it doesnt appear with my other applications even when its open.
I have tried restarting, I am just wondering if there is another way to unmute things like in control panel or if there is a way to make it appear with the other applications in the Volume Mixer.
Thanks.
It happened once for me with Firefox. I couldn't see it in the mixer. But the next time I started it (not sure if I had rebooted), I had several other programs closed. I just saw it there, normally, and I could unmute it.
    HP tx2001au Entertainment Notebook PC
    AMD Turion TL-58 64x2, 1.9 GHz
    2GB
    nVidia GeForce 6150 Go (128 MB)
    Hitachi 150 GB
Yes, the Volume icon should come back after a re-boot, but you can also bring it back this way:
Right click the Start button, select Properties, Notification Area, and in the Systems Icons list, check the "Volume" box. (You can also do this from the Task Bar and Start Menu in the Control Panel.)
    HP Pavillion dv5t (Gen. 1)
    1680 x 1050
    built in - HP
    max
No, Imperfect1, Ardaos is saying that the program is not appearing in the Volume Mixer. The volume icon hasn't disappeared. He can access the Volume Mixer.
    2GB
    Hitachi 150 GB
Sorry, I misunderstood. I thought when he said "it" didn't appear any longer that he was referring to the Volume icon.
    1680 x 1050
    built in - HP
    max
I think shy of reinstalling your audio drivers, there's not much chance of it coming back if you were unsuccessful on reboot :-(
MrNeeds
    Intel Q6600 @ 2.8GHz
    Evga NF78-CK-132-A 3-Way SLI
    EVGA 560 GTX SC FTW 1GB
    Antec 900 Gaming Case
    Logitech generic keyboard
    16Mb Sky bb
