weird boot problem..
mathews2010
Banned
ok well i went into my HDD and scheduled an error checking..well windows loaded as normal, but no error checking occurred i guess...now after the green bar is done, the screen hangs on a black screen.. any idea?
Mathews,
Did you change the boot screen? If so, see the NOTE in this tutorial. Also, try doing it from both methods.
How to Use Check Disk in Vista
Your welcome Mathews,
Usually the command prompt will pickup where the user interface leaves off. ;)
Mathews,
I'm not sure why Method One does not always work on some computers. Something to do with the permissions would be my guess. It's a 50/50 with me. I just use the command prompt. It always work. ;)
Glad it worked for you.
