weird keyboard problem
eldergolfer21
i recently bought an amd 940 and everything works fine except when i want to play games. for some reason my keyboard does not want to respond correctly. for example, i will start walking forward...still holding "w" and all the sudden i stop. i am still holding "w" down but not going anywhere. i have to let go and press it again but it continues to happen. this happens with all directional buttons as well.
problem exists in every game from crysis to halo and a few in between
now this sounds like a stupid problem from just getting a new processor but it had NO problems with my amd 7750.
sounds stupid but i could use some help
Hello eldergolfer21,
Can you list your system specs, thanks.
    Self Build
    Asus P5Q Premium
    2 x ASUS EAH 4870 X 2 (Quad)
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
everything is at stock speeds. this problem only came about once i put the cpu in. i have not reinstalled vista of anything...i dont think that would help tho.
is your keyboard wireless? mine does that sometimes cause it is wireless
    CUSTOM BUILT BY ME
    8BG PC5300 4 x 2GB OCZ
    Onboard 7.1 HD AUDIO
    55" Vizio LCD
    1600 x 1200 HD
    GENERIC
    MICROSOFT WIRELESS MOUSE
    MICROSOFT WIRELESS KEYBOARD
    CABLE 15MBPS
Want kind of wireless keyboard do you have? Are there specific drivers available for download from the manufacturers website?
Logitech Support
    Acer Extensa 5620-6396
    Intel Core 2 Duo 5750
    4GB DDR2
    ATI Radeon HD 2400 XT
    Laptop 15.4 LCD
    1280*768
    Logitech G11 Gaming Keyboars
i knew i should have mentioned that...
its a microsoft oem keyboard and mouse
is it possible at all to have some MINOR defect in the processor or motherboard? i only had the processor for less than 30 days so i can exchange it(cant refund). like i mentioned before, i did NOT have this problem with my 7750. im not really planning on going back to that though
have you tried to download the driver software from micro$oft yet and see if that helps with the issue.
    CUSTOM BUILT BY ME
    55" Vizio LCD
    1600 x 1200 HD
    GENERIC
    CABLE 15MBPS
yes...the wierd thing is that this ONLY happens for games. i can sit here hold down any letter all day long, but when i am playing a game that is when it messes up. my movement stops even though i am still holding the key down. when i tried to play halo it did say something about not having enough memory, even though i have 4 gigs running 5-5-5-15 2T @ 1066
Are you using a PS/2 (Round Purple/Green) Connection, or a USB connection?
Try using another keyboard and see if the problem persists. If it does, you can rule out drivers, and then look at hardware malfunctions.
    4GB DDR2
    Laptop 15.4 LCD
    1280*768
i switch out for my old dell ps/2 keyboard and the problem stopped. now i moved the receiver closer to the key board and the problem went away...for now. what i am worried now is that it might come back and i do not want to go back to wired board. i have not had a problem with signal strength before wherever it was placed. right now the receiver is not in an ideal spot but it works. if anyone else has anything let me know. i did update my bios to make sure that the cpu was compatible(it was already ok before the flash, but i wanted to rule that out). the flash did contain a cpu update. anyway, i still would like to get this figured out in case it comes up again and the fix might not be as simple and i would be less tolerable to the change.
