werid sound...new card
hackdot
well i just bought all my computer parts and put it togther today and such finaly got it all set up, i go to play a game and as soon as it starts my new
XFX radeon hd 6850 starts to make this werid screeching nose or somthing else its like a beep that is made to keep going but no beep...i believe its the card and this only happends when i play games or watch videos on netflix not youtube
any tips? dont really wanna send the card back...:cry:
if i keep playing the game the sound goes and comes...
It might be the fan. I don't know if they are replaceable on graphics cards If it where me I'd take it back.
    Windows 7 Pro & 10 Pro
    HP Pavillion Elite HPE-250f
    8 gb
    ATI Radeon HD 5770 1 gb ram
    Alienware 25 AW2521HF
    1920x1080 &1680x1050
    1 TB & 500 GB
Ik think its capacitor whine. Basically as power goes through them they buzz. You might want to think about returning it, as i've not heard ati with the issue.
    Dual L5639 // i7 950 @ 4.0Ghz
    gtx 560 ti // gtx 260-216
    Dual 22" // Headless
i no longer hear a beep, its the sound card fan but **** it is a load one or it might be the capactior i do not know, this is my first time having a real non crappy grapics card
Those fans can be noisy especially under a full load.
    8 gb
    1 TB & 500 GB
Is the card designed to use two power plugs? If so and you don't have one plugged in, the mobo will emit a screeching noise. I used to have two cards in SLI and one of them died. I disconnected the dead one and the noise was unbearable.
    Vista Home Premium 64 bit SP2
    Cyberpower
    Intel Quad CPU Q6700 2.67 GHZ
    NVIDIA 780i
    MSI GTX 560 TI Twin Frozr
    Sound Blaster SB Audigy
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI WDC WD20
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
I can confirm about the screech being a power problem. Also have a look on your mobo, there may be a molex connector or other type of connector that is required. What mobo are you using?
    I5 3570K
    Gigabyte Z77-DS3H
    Gigabyte Geforce GTX 660 TI
    creative x-fi
    Both 1680 x 1050
    Technika TKOPTM2
    Logik
it takes like 2 prongs for it..4 and 4 i guess....i plug a 4 in but the other one is a 4 with a 2 connected so i ignore the the 2nd and the use the 4 for it
Could you take a picture?
    8 gb
    1 TB & 500 GB
You need to get both connections wired. What type of PSU and MOBO do you have?
a 500 watt or greater PSU is recommended for this card.
    I5 3570K
    Gigabyte Z77-DS3H
    creative x-fi
    Both 1680 x 1050
    Technika TKOPTM2
    Logik
Strange thing is that AMD doesn't specify the connection requirements on the web. I found a review which indicates that it needs two PCI 6 pin connectors.
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
