I bought a HP Pavilion Laptop which came with Vista Home Premium 64bit installed on it. There are however a number of 16-bit DOS applications that I need to run for college work.
I tried using DOSBox but it seems that the HP Pavilion laptop keypad isn't compatible. I can't even get my C drive to mount because there's no key that prints the ':' character.
So I guess the only option is to install 32 bit vista. A friend of mine has a 32 bit vista installation. If I install a copy using his activation key and then later (after installation)change it to my 64bit key, will it work?
Thanks in advance
Thanks in advance
