Windows DVD Maker Problem
Canam778
I made a slide show movie in Windows Movie Maker6(Vista) when I click on Publish To DVD it saves it and opens Windows DVD Maker. This where it goes strange:
The movie that comes up is an older movie that I had made earlier. I can't get kid of it in order to work with my new slide show movie. I have deleted the old movie file from my computer, however when I start over again the same OLD movie comes up again on DVD Maker.
Any suggestions would be appreciated.
Looks like you may have deleted the original, but the saved project is a copy saved on your pc. You should be able to find it by typing it's name into the start search box.
Hope that helps
SIW2
    Vista
    Intel E8400
    ASRock1333-GLAN R2.0
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
    ballistix 2x8gb 3200
