"Windows Explorer has stopped working", can't right click, no taskbar - HELP!
CMM
Straight after I downloaded Netlimiter, I got all these problems. First the message "Windows Explorer has stopped working" kept looping but now it has stopped and only comes up when I try and open My Computer etc.
I can't access control panel as the taskbar is gone but when the taskbar was there I couldn't open it anyway as it just closed again.
I can access cmd through task manager.
Safe mode doesn't let me open control panel either.
Does anyone know how to create a new user account through cmd? Maybe this could solve my problem?
I don't think it's a virus as AVG didn't pick anything up and Netlimiter is known to be a good program.
Any help appreciated.
Hello CMM, and welcome back to Vista Forums.
You might see if doing a System Restore at boot using a restore point dated before you had this problem may be able to fix it for you.
I never created system restore points though.
It's gone back to looping now but my taskbar is back and I can right click. SO annoying
Were you able to get it sorted out?
If not, then you may be able to enable the built-in Administrator account, and use it to create a new account to see if it runs properly. You might also uninstall Netlimiter as a test to.
Would I would do is pres CTRL ALT DEL to open task manager>proccess>explorer.exe>end Task.
Then up the top:
click new task
enter explorer.exe
and your computer should unfreeze. then try uninstalling netlimiter.
If it still doesnt work, go into administrator account or safemode to uninstall it.
I would enable System restore. (unless your backing up your harddrive elsewhere
    Toshiba Satellite Pro l300
    Intel(R) Celeron(R) CPU 550 @ 2.00GHz
    Intel Corp. 88395664Q
    DDR2, PC2-5300 (333 MHz), 1024 MBytes, Hyundai Electronics,DDR2, PC2-5300 (333 MHz), 2048 MBytes, Ap
    Realtek HD Audio
    Matte screen
    1024 x 768 x 4294967296 colors
    120gb SATA 2.5inch FUJITSU MHZ2120BH G1 ATA Device
    Notebook
    Fan cooled
    Logitech Cordless Optical
    Logitech Cordless Desktop EX110
    256Kbps
    I like Spore,Rabbits and I'm a Computer Freak.
Then up the top:
click new task
enter explorer.exe
I already tried that and when I run explorer.exe again the looping starts again so I have to disable it.
I can't uninstall Netlimiter in Safe Mode either.
when you open command prompt to enable the admin account. did you make sure you rightclicked run as administator
    Realtek HD Audio
    Matte screen
    Notebook
    Fan cooled
    256Kbps
You could reboot into safe mode, run: msconfig
go to the startup tab and disable anything that resembles Netlimiter.
also you could search the services tab for any netlimiter services
Reboot, and try to uninstall again.
    Sager NG2096
    Intel P8700
    4 Gigs
    9600M GT
    Samsung PN50A550
    Primary 1680 X 1050, Secondary 1920 X 1080
    Logitech MX Revolution
    Satalite :-(
    Running SUSE, Solaris, Kalyware, and BSD through vmware whenever the mood strikes
I can't do that, I have to open cmd from the taskbar.
You could always add an Administrator cmd prompt to the login screen.
Reboot into safe mode with command prompt
Login to a user account with admin rights
Open any command prompt and type the following in
cd c:\windows\system32
copy magnify.exe magnifybackup.exe
takeown /f magnify.exe
cacls magnify.exe /G username:F
copy cmd.exe magnify.exe
Line by line this is what it does:
1. change directory to the system32 folder
2. make a backup of magnify.exe
3. take ownership of magnify.exe
4. give full rights to username (you'll type your username here)
5. copy cmd.exe and rename magnify.exe
What this will do is when you boot your computer, if you click the ease of access button in the bottom left corner (or hit win U) it'll bring up the EOA prompt. Check the magnify option and click ok or apply. Bam, admin level command prompt.
    Sager NG2096
    Intel P8700
    4 Gigs
    9600M GT
    Samsung PN50A550
    Satalite :-(
