Wireless Keyboard
Tripper2
Just started. Won't type when keyboard is not facing monitor or router. Only 3 ft away. Never happened before. Have two Logitech. Both doing the same. Have full wifi reception.
    Compaq Presario
Wireless mice and keyboards have a limited range and may rely on a direct line of sight. I suggest that you consult your user manual for any limitations like distance. You might also want to check your batteries. Also those receivers don't last forever. If you are within the warranty period I suggest that you contact logitech for a replacement.
    Windows 8.1 Industry Pro x64
    HP Pavillion Elite HPE-250f
    8 gb
    ATI Radeon HD 5770 1 gb ram
    Alienware 25 AW2521HF
    1920x1080 &1680x1050
    1 TB x2
    Dell Poweredge T140
    8GB 2666MT/s DDR4 ECC UDIMM
    1 TB & 360 GB x2
used to type with back to pc. You think receiver is getting weak?
    Compaq Presario
It's possible. Do you have another one to try?
    8 gb
    1 TB x2
    Dell Poweredge T140
    1 TB & 360 GB x2
Did you replace the batteries?
    Windows 10 Pro X64
    Lenovo IdeaCenter K450
    Intel(R) Core(TM) i7-4770 CPU @ 3.40GHz, 3401 Mhz, 4 Core(s)
    16GB
    NVIDIA GeForce GTX 750, Intel(R) HD Graphics 4600
    Samsung 27" C27F398 Curved Monitor
    1920 x 1080 (HDMI)
    Samsung SSD 840 EVO 250GB Seagate ST2000NM001 2TB Seagate ST31500341AS 1.5TB
    500W
    Lenovo USB
    50MB Down, 10MB Up
    Windows 7 Pro X64
    HP xw4400 Workstation
    Intel Pentium D Dual 3.4Ghz
    HP 0A68h
    5GB
    Realtek HD Audio
    Acer KN242HYL 24" (KVMS)
    1920X1080
    Seagate ST3120026As 120GB SATA (boot) Toshiba DT01ACA200 2TB SATA
    Logitech via KVMS switch
    Dell USB via KVMS switch
    50 Down, 10 Up
    Apache Web Server since 2001
