Wireless problems
j8ey
Hi all, thanks for reading.
I have a ralink wireless adapter but cant seem to find the right driver for it. A while ago I spend about a day downloading, installing, updating and restarting untill it randomly worked. Then along came windows update to screw it all up! Now with some drivers it is constantly connecting and disconnecting every minute or so and with some with just doesn't work all together. Is the right driver out there? And if not am I going to have the same problems with an adapter from a reputable manufacturer?
Thanks, Joey
What card? Is it offically supported by Vista/win7?
If you get a new card, no, you most likely won't have issues... It comes down to this... Most cards are bout $20, so is fussing with a picky card worth your time?
*This only stands true if your card isn't newish...
    Dual L5639 // i7 950 @ 4.0Ghz
    gtx 560 ti // gtx 260-216
    Dual 22" // Headless
