Wont load past login screen?
arivu93
Ive looked at all the other similar messages in the forums and none seem to help me. I turned off my computer yesterday then turned it on again and switched it off again using the power switch repeatedly yesterday in a span of a few mins. I then went out for a day and when i came back home and tried to boot my computer again vista wouldnt load the login screen. I changed my loading screen and it gets past that alright but when it gets to the logon screen everything just turns black?
    i forget
    ASUS Striker Extreme Republic of Gamers Series - motherboard
    8 Gbs of ram
    Geforce 9800 GTX
    idk
    i forget
    i forget
    i forget
I dont want to do that because ill lose a lot of my data and i never backed up after a few months ago so all the work and other stuff will be gone
i took a pic of the screen so i could read the error report:
STOP:COOOO21 { FATAL SYSTEM ERROR }
The initial session process or system process terminated unexpectedly with a status of 0X00000000 ( 0xC0000001 0x00100450 )
    i forget
    8 Gbs of ram
    Geforce 9800 GTX
    idk
    i forget
    i forget
    i forget
You won't lose your files on your machine with system restore.
    HP Pavilion a6460t
    Intel Core 2 Duo E4700 2.6 GHz
    Pegatron Benecia
    4 Gigs
    Nividia 8500GT 512
    HP w2207h 22 inch LCD
    1680 x 1050
NOTE: Do a system restore not to be confused with system recovery. System recovery will cause you to lose your data. However at the begining of bootup on my system I believe I have to tap F11 key repeatedly to access the system recovery page and on that page I click advance options to get to system restore option. Don't be reluctent to explore the the system recovery menu. If you are about to lose your files you will get warned that that will happen if you continue. Also you might can access startup repair from that screen also. I would try startup repair first anyway. I hope this works. I believe it will.
    HP Pavilion a6460t
    Pegatron Benecia
    4 Gigs
    Nividia 8500GT 512
    1680 x 1050
So i put my orginial vista ultimate cd and went to the repair menu from there but for some reason it makes a new os link called vista ultimate etc (restored) and when i go to that i login all right and everything but everything is gone! not from my harddrive its still in the main folder but for some reason none of the apps i installed or things i downloaded will show up? ne ideas?
    i forget
    8 Gbs of ram
    Geforce 9800 GTX
    idk
    i forget
    i forget
    i forget
thing is mate ...
systeam
restore ? = takes it back to factory settings soo all that stuff on your hardrive still be there but the apps and things you installed will be gone as you gone back to factory settings(as if you were to turn it on for the 1st time) if you can were cuming from ....but i sure you can get them back :) sure most your data was on your hardrive :)
