Search Context Menu Item - Restore After Vista SP1
How to Restore the Search Context Menu Item after Installing the Vista SP1
When you install the Vista SP1, it removes Search from the Context (right click) menu of the Start menu button and Folders. This will show you how to restore the Search context menu item with the Vista SP1 still installed. For more information on what the SP1 changes, see: Microsoft Help and Support: KB941946 and Windows Vista Blog: Experiencing Windows Vista Service Pack 1 Beta
The Search button on the right dark side in the Start menu has also been removed by the Vista SP1. This will show you how to restore it: How to Restore the Start Menu Button after Installing the Vista SP1
EXAMPLE: Start Button Context Menu with SP1 and Restored
EXAMPLE: Folder Context Menu with SP1 and Restored
EXAMPLE: Drive Context Menu with SP1 and Restored
OPTION ONE
Using a REG File Download
1. To Remove the Search Context Menu Item
Remove_ContextMenu_Search.reg
download
B) Go to step 3.​
2. To Restore the Search Context Menu Item
Restore_ContextMenu_Search.reg
download
4. Right click the .reg (On Desktop) file and click on Merge.​
5. Click on the Run button for Security Warning pop-up.​
6. Click on Continue (UAC), Yes, and then OK when prompted.​
7. You may need to Log off and log on, or restart the computer to apply the changes.​
8. When done, you can delete the .reg file (On Desktop).​
OPTION TWO
Through Registy Editor
1. Open the Start Menu.​
4. For the File and Folder Context Menu
A) In regedit, go to: (See screenshot below)​
HKEY_CLASSES_ROOT\Directory\shell\find
B) Go to step 7 or 8.​
5. For the Drive Context Menu
HKEY_CLASSES_ROOT\Drive\shell\find
6. For the Compressed (ZIP) Folders
HKEY_CLASSES_ROOT\CompressedFolder\shell\find
7. To Restore the Search Context Menu Item
A) In the right pane, right click on LegacyDisable and click Delete. (See screenshots below steps 4, 5, or 6)​
C) The registry will now look like similar to this. (See screenshot below)​
NOTE: This example is from step 4. Just substitute either step 4, 5, or 6 for the one you selected instead.​
D) Go to step 9.​
8. To Remove the Search Context Menu Item
A) In the right pane, right click on a empty area and click New and String Value. (See screenshot above)​
B) Type LegacyDisable and press Enter. (See screenshots below steps 4, 5, or 6)​
9. Close regedit.​
10. You may need to Log off and log on, or restart the computer to apply the changes.​
  • Remove_ContextMenu_Search.reg
  • Restore_ContextMenu_Search.reg
Shawn,
If I right click on a drive, I still don't see the Search item. Only on subfolders. For example, I want to do a Search on everything on an SD card E: by it is not there on a right click. I have to go down to a subfolder. Know of any way to do this as well?
Hi Bob-C,
This will not add Search to the context menu for a drive, only the Start menu button and folders. :(
You can use Advanced Search to do what you want. Just select the E:\ drive in the Location drop down menu to search from. This tutorial will show you how to if needed.
http://www.vistax64.com/tutorials/75451-advanced-search.html
Update:
Search is now included for the Drive context menu in this tutorial.
    1TB Samsung 990 PRO M.2,
    4TB Samsung 990 PRO PRO M.2,
    Galaxy S23 Plus phone
Your welcome Karl.
I've been trying to find info about...how can I add "Search" in Right Click-Context Menu, from a web page? I have it on my XP computer.
    Hewlett-Packard/a6210z Desktop
    AMD Athlon(tm) 64 Processor 3800+
    2GB
Hi TWF,
There is not a Search context menu item in Internet Explorer for Vista, but I'm not sure what would be different than what the Internet Explorer Search box would offer. If you mean to search inside the current webpage, then the Find window might be what you are wanting.
http://www.vistax64.com/tutorials/119469-find.html
If the above is not what you mean or want, then please let me know with more details on what you want to search for. Maybe there will be an alternative method available.
Hi, Shawn.
No, I don't mean the "Find" feature. I'd like to be able to highlight a specific word(s). Then, right-click that word, which that menu would have "Search". It would save time, by not having to copy/paste into "Search" box & having to click to "Search". I hope this helps explain, because it was something that could be done on WinXP, by adding the "Search" w/a RegEdit file...downloaded from a WinXP Tips/Tweaks site.
Thx.
    2GB
Great :huh: That just plain sucks! After reading/watching the IE8 Beta info, I'm not too sure it'll be what I'd be interested in. However, I do appreciate your assistance.
Oh, hey, do you think that RegEdit file I did on my WinXP IE7 will work?
    2GB
Many items for XP will also work with Vista, so you could give it a try to see. To be safe, I would create a restore point first in case you need to do a System Restore afterwards to repair the registry.
I hope it works for you.
:D I did as you recommended. It added the "Search" as I'd hoped. So far, so good. Do you know how it's done, yourself? If not, would you like the ".exe" file that I used? I'd be happy to pass along to anyone else this may help. It wasn't a RegEdit command, as I 1st thought.
Thx.
    2GB
TWF498,
I'm happy to hear that it is working for you so far. Sure, please post a link to where you got it from and I'll take a look at it to see what I can do with it to adapt it for a possible tutorial.
Thank you,
So, you don't just want me to upload the .exe file, from my computer? I see there's a place to add attachments, in the posts. Either way, it's fine w/me.
Thx.
    2GB
I don't mind if you attach it in a ZIP file. It's just that I will not be able to view the contents of the file to see what changes it makes, but other may decide to use it anyway to help them. :geek:
    2GB
Thank you twf498.
The newer IE8 beta offers this feature, but in a different way. You highlight what you want to search and click on the small box with a arrow above it to search with any default search provider (ex: Google) that you had set for IE8. That way you can just click on it once instead of having to modify IE7.
LOL, it's called an Accelerator feature in IE8 now. Go figure. ;) It works pretty well.
Internet Explorer 8: Faster and easier
Hello Druekberg,
This search feature was removed due to a antitrust lawsuit that Microsoft lost with Google. Microsoft had no choice but to comply and remove it, but nothing says that the end user can't add it back though. ;)
Brink,
My apologies, but I have another question.
Is there a way to restore the "Search..." context menu item that appears when right-clicking "Computer"?
    HP-Pavilion FK786AA-ABA s3600f
    Intel Pentium Dual CPU E2180 @ 2.00GHz
    Irvine
    2GB DDR2
    NVIDIA GeForce 7100
    Integrated Realtek ALC888S
    1024 x 768 (32 bit) (85Hz)
