How to Use the Snipping Tool in Vista
How to Use the Snipping Tool in Vista and Windows 7
This tutorial will show you how to use the 'Snipping Tool' to select an area of an on-screen image for use in other programs and applications.
1) In this tutorial, I will show you how to use the 'Vista Snipping Tool' to select an area of an on-screen image for use in other programs and applications. The image I have chosen for this example is found in the 'Sample Pictures' folder, and is the 'Toco Toucan'. The first image shows the full picture, and this example will show you how to select the Toucan from the picture. For details on how this image was inserted into the tutorial, refer to the footnote at the end.
2) With the screen showing the image from which you wish to make your selection, you need to invoke the 'Snipping Tool'. To do this, click the start orb and type 'Snipping Tool' into the search box.
NOTE: The Snipping Tool is not available in the Vista Home Basic edition. This is a part of the Tablet PC Optional Components in Vista only, and is turned on in Windows Features by default in Vista.
3) In the 'Programs' section of the results panel, click this item and the initial tool will appear. Note that you can move this tool around the screen so that it does not obstruct the area you are interested in. Note also that the rest of the screen is dimmed. This image shows the tool over a section of the 'Waterfall', another image from the 'Sample Pictures' folder. I chose that image here because I felt that the 'Toco Toucan' image was too green to show the effect of the dimmed screen.
4) You may change the type of snip by clicking on the downward pointing arrow on the 'New' button. Here I have selected the 'Rectangular Snip'.
If you want to take a screen capture of just a single window, use the the Window Snip selection to automatically pick a window to get snipped.
5) The default setting for the 'Snipping Tool' is to have a red band around the snip (you can change the colour of this band if you wish). I have turned this option off for this tutorial, but to illustrate this option, the next 2 images show this effect, firstly enabled and secondly disabled. Note that it still appears whilst you are selecting the snip so that you know what you are selecting. This option is found under 'Snipping Tools Options (click the 'Options' button to open this dialogue box. The option you require is 'Show selection ink after snips are captured'.
6) Next, click on the image and drag the red band so that it encompasses the section of the image that you are interested in. Note that this portion of the image will be highlighted. When you release the mouse button, the following screen will appear.
7) Click on the save icon (the picture of a floppy disk) and select a file name and location for the file. You can then use the image created for whatever purpose you require. The rest of this tutorial will show you how to attach this image to a post for submitting to the forums.
8) When you submit a post to the forums, you do so by entering the text of your post into the message box.
9) If you look at the toolbar in this image, you will see an icon in the form of a paperclip (highlighted in green above). It is this option that you select in order to manage images. This is the initial display of this screen before images are added.
10) In the section 'Upload File from your Computer', click 'Browse...' next to the first available slot and locate the required file. This file will appear in the address box as illustrated by the first of the next two images. Although this example shows just a single file, you can browse and locate up to 4 files at a time. When you have done, click 'Upload' to transfer these files to the forum servers, the result of which is indicated in the second of these two images. You can then repeat the procedure to add more files if needed. Obviously, your list of files will be different to mine.
11) When you have finished uploading files, click on 'Close this window' to return to the main message box.
12) When you wish to insert an uploaded image into your post, click on the paperclip again and select the required image from the drop down list. The image will be inserted at the current cursor position, and will be shown as
where 'XXXX' is a unique reference number allocated to your image by the forum servers. As this tutorial is about selecting the Toucan, the final image shows the result.
If you upload a lot of attachments and want to them to all appear in a row, then you can use the Insert All link at the bottom of the attachments
FOOTNOTE: This section shows how the original image was inserted in to this Tutorial.
13) Upload your image files as described above. Notice the list of 'Current Attachments' in the 2nd image at step 10. Right-click on the required attachment and select 'Copy Shortcut' from the menu that appears.
14) Referring to the image in step 8, click on the 'Insert Image' icon (highlighted in blue). The following dialogue box appears.
15) Delete the contents of the text box ("http://"), and in its place paste the shortcut created in step 13.
16) When you wish to insert this image into your post, it is a similar procedure to inserting normal attachments as described in step 12, except that you click on the 'Insert Image' icon instead. Again, the image will be inserted at the current cursor position, and will be shown as "
", where 'ADDRESS' is the shortcut to the image created in steps 13 to 15.
17) This resizes the image so that it fits the post, but when the image is clicked on the full image is shown. Click and hold to move the image, click and release to return to the post.
Hello Dwarf,
Yes very good job!
Thank you very much.
Later :shock: Ted
    * BFK Customs *
    Intel C2Q 9550 Yorkfield
    ASUS P5Q Pro
    8GB Dominator 8500C5D
    XFX ATI 1GB 4870 XXX
    Realtek HD 7-1
    1920x1080P & 1920x1200
    Corsair 620HX
    CM Cosmos RC-1000
    HP Enhansed Multimedia
    Razer Diamondback 3G
    18.6Mb/s
    My First Build ;)
Yes, nice tutorial.
I might of added just one thing. You must have PC Tablet optional tools enabled in the windows features list. When I first set up Vista I turned that off as I didn't have a tablet pc. Had a heck of a time finding the snipping tool.
Thanks
Gary
    Intel Core2 Quad Q6600
    Creative SB X-Fi
    HP w2207 + HPvs15
    1680x1050 + 1024x768
    2-WD5000AAKS-500 GB
    WD 5000AAV-500 GB external
    Microsoft Comfort Curve
    MX Revolution
    Wacom Intuos 2 Graphics Tablet
    Experience Index=5.5
Hi Gary,
This is just a standard configuration of Vista Home Premium 32-bit with SP1. As far as I am aware, the standard configuration of Vista installs ALL features for that edition. I haven't enabled or disabled any features in my setup. The features that you don't want can, in some cases but not all, be uninstalled afterwards. This is in stark contrast to earlier editions of Windows such as 9X and XP where you are given the option of amending the optional components during the initial installation process of the OS. If you are not sure where a program is located, typing its name in to the search box as described is really the easiest way of finding it.
Dwarf
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Iomega 1.5TB Ext USB 2.0
    WD 2.0TB Ext USB 3.0
    Gigabyte IF233
Hi Dwarf,
Great tutorial on Snipping Tool - very clear.
For those who don't want to have Tablet PC running ( its 741mb ) just to use the Snipping Tool - try FaststoneCapture53. This is a powerful capture tool with image conversion, etc. ( only 1.4mb ) and it's free from
FastStone Capture 5.3 winAddons.com
SIW2
    Vista
    Intel E8400
    ASRock1333-GLAN R2.0
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
    ballistix 2x8gb 3200
Hi John & Shawn,
I have just had another look at this Tutorial of mine, and I notice that some attachments weren't displaying. These attachments, 5873, 5874 and 5875 have been added either by yourselves or one of the moderators together with extra information, which I wasn't aware of at the time of writing and which is gratefully received. Just curious about why these particular attachments don't display.
Dwarf
    Gigabyte IF233
great info Dwarf!!
only yesterday i was trying to explain to someone how to find & use this..:)
    ME.....
    Q9450 @ 3.6ghz
    P5K PREMIUM
    8GB 1066mhz buffalo firestix
    HD 5970
    20'' syncmaster
    XCILIO 850w
    unknown ATX
    Arctic cooler pro 775
    logitech EX110
    logitech cordless optical
    2mb
Thank you for the tutorial. I think I may still have some hair left. Trying to figure this out took a lot of hair pulling.
Is it possible to put the snipping tool function on the taskbar?
    Gigabyte IF233
Sure,
Find Snipping Tool in the start menu, right click it and from your right click menu select Add to Quick Launch.
Hope this helps
SIW2
    Vista
    Intel E8400
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
Great post Dwarf. I am relatively new to Vista and I was not aware of the snipping tool.
+2 Reps
    hp m9250f
    Core 2 Quad 6700
    Asus
    4GB 800MHz
    8600GT 512MB
    ViewSonic 19" HD Widescreen LCD
    1440 x 900
    2 Seagate 500GB SATA HD
    350 Watt
    wireless
    wireless
    Extreme High Speed w/ Turbo Boost
good job mate!
cheers
    MEDION
    Intel Core 2 Duo (2.0 Gigahertz each core)
    3 Gigabytes
    nvidia GeForce 9300M G (128 megabytes)
    1280x1800
    1 Hard Drive with 320 gigabytes of space
    Built in Webcam, fingerprint sensor, dvd/cd burner, wireless internet
Great tutorial Dwarf! A very useful tool... Thanks!
    HP Pavillion Elite / m9250f
    Intel Core 2 Quad Q6700 2.66 GHz
    ASUSTeK Benicia
    4.0 GB DDR2-SDRAM (PC2-6400 / 800 MHz (Samsung)
    NVIDIA GeForce 8600 GT
    Realtek HD Audio
    LG L1932TQ - 19 inch, 4ms refresh
    1280 x 960
    1 Terabyte, consisting of
    2 Hitachi SATA 465 GB w/32 MB buffers
    Operating in RAID Mode 1
    HP Pavillion Elite
    Controlled by SpeedFan Ver. 4.35
    Microsoft eHome Wireless
    Microsoft HID-compliant Wireless
    1 MB/sec +/-
    Hughes HN7000s Sat. Modem,
    HP Photosmart C4180 All-In-One,
    TrippLiteUPS,
    Realtek High Def. digital coaxial to:
    Kenwood KRF-X9080D 7.1 Audio-Video Controller putting out
    110 watts per channel into:
    2 Infinity RS IIIa (front),
    2 Infinity RS 5 (surround),
    1 Klipch CN4 (center),
    1 Kenwood KB-700 powered sub (1978 vintage) and
    2 old Kenwood floor standing monitors (sur. back)
hi
Still trying Post properly or Quote
yea great job, as I read my Home basic 32 bit don't come wirh that Tablet PC settings Snipping tool Option
How do I make that free Faststone Capture 5.3 work? (copy extract)
don't see Instruction on that
tanks
Silverhair
Hi Dwarf,
SIW2
Thanks Dwarf for a well presented and easily followed Tutorial, which is now firmly Bookmarked!
I too was beginning to join the ranks of the follicularly challenged:shock:
    nVidia GeForce Go 7300, 128MB
    1280x800x60Hertz [max.]
For some odd reason I get "No items match your search". How come? Where did the tool go?? You tutorial worked for me before, lots of times. Please help??
Thanx for your help!!
Hi Ilya,
You need to have the Tablet PC service running to access the snipping tool.
You may have turned it off as it's a big program (731mb).
Try checking under Control Panel>Uninstall a program>Turn Windows Features on or off.
If you do not wish to have the Tablet PC program installed and running just to use the snipping tool, you could try Faststone Capture53 - it's free and in my opinion, better than the snipping tool - it's only 1.4mb.
FastStone Capture 5.3 - eSnips, share anything
Hope it helps
SIW2
    Vista
    Intel E8400
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
