Workgroup Password
Workgroup Password Problems
How to Fix a Password Not Being Accepted When Connecting to a Workgroup Computer in Vista
This will show you how to fix a password from not being accepted when connecting to a workgroup computer.
Method One
Through Local Security Policy
This method is for the Vista Business, Ultimate, and Enterprise editions only. For Vista Home Basic and Home Premium editions, see METHOD TWO below. See the video below to also help
1. Open Administrative Tools.​
NOTE: In Start Menu or Control Panel (Classic View).
2. Click on Local Security Policy.​
3. In the left pane, click the triangle next to Local Policy.​
4. In the left pane, click on Security Options.​
5. In the right pane near the bottom, click on Network security: LAN manager authentication level.​
6. Click the drop down box, and click Send LM & NTLM - use NTLMv2 session security if negotiated.​
7. Click on OK.​
8. Restart the computer.​
Method Two
Through the Registry
This method is for all Vista versions. See the video below to also help.
1. Open the Start Menu.​
4. In regedit, go to:​
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Lsa
5. In the right pane, right click LmCompatibilityLevel and click Modify.​
NOTE: If it doesn't already exist, create a DWORD value named LmCompatibilityLevel
6. Set the value to 1
7. Reboot​
Thank you for this solution, it is very much appreciated. Now if I could find a way to avoid answering a 'do you want to do ... ' question every time I try to do anything.
Thanks again.
Eustace Mendis.
    Windows 11 Workstation
    Ryzen 9 5950X
    Creative
    Drive
    1500W ThermalTake Toughpower
    ThermalTake Level 10 GT
    Enermax Liqtech 240
    Surface Ergonomic.
    Logitech Performance MX
    350 Mb/s
    WinTV NovaTD
    HP CP1515n Color Laser
    Microsoft LifeCam Cinema
    APC 750i Smart UPS
    windows 10
    Surface Pro 3
    Intel HD Graphics 4400
    12" Multi Touch
    2160 x 144
    128GB
    yes
    350 Mb/s
z3r010:
Forgive the belated thanks for this tip. Too busy with other stuff (on my Macs) to get to this, but I will in the next day or two. Thank you.
Using method 2 described above, I changed the value from 3 to 1 and rebooted - this has had no effect at all - the problem still exists.
^ ditto, i am having the same problem. i am running on vista home premium, but method 2 had no effect. my PC has no trouble connecting to my laptop to access files, but the problem occurs when i try to do it the other way around. i get the error message, incorrect login, when i try to connect. is there an alternative method to fix this problem? thanks in advance.
Hi Duce,
Have you set a password for the useraccount your trying to login with?
Steven
Check if the user name on the vista is different from the one on the other system.
Normal practice is to create the same user name on both the machines. This somehow doesn't work well with vista. so go ahead and create a different username with a different password on the vista, than the other machine.
I have the same problem but the solution did not work for me. My Vista Business is the laptop (client) and the PC is Windows XP. I couldn't use the same named account to connect as because I use no password and I read somewhere that is disallowed. So I created a new user on the PC to connect through.
The weird thing is that I had been mapping a network drive just fine. It worked smoothly for several weeks. Then I physically moved the PC to the next room or did something else on one of the systems that I am not aware of, and now I can't get it to work again.
More gory details in:
windows logon unsuccessful during map network drive : Wireless, Internet, and Networking : Windows Vista : Microsoft Answers Forums
I try so hard to log all my admin actions to avoid problems like this, but didn't write anything down.
I couldn't find this information anywhere else. I need to map to my corporate network shares on Novell servers, and I'm using a laptop with Vista Home Premium. I kept getting that nasty "logon unsuccessful" error. I made sure I selected the login with a different user name option, and used my work credentials, but it kept putting my laptop name in front of my user name. Changing this setting did the trick. Now I can see the shares I need to. Thanks!
    eMachines T5234
    AMD Athlon 64 X2 4000+ 2.1GHz, 2x512KB L2 cache
    1024MB 667MHz DDR2 dual-channel memory (2 × 512MB)
    1024 x 768 x 75 hertz
    WDC WD32 00AAJS-00VWA SCSI Disk Device
    PS/2 Compatible Mouse
    20M download, 5M upload
    Verizon FIOS
    ATAPI DVD A DH16A1P ATA Device
I have a vista ultimate sp1 laptop and xp sp3 desktop connected on teh same workgroup and router (linksys wireless router, does dhcp). i am unable to access to printer or shared folders from vista to xp desktop and viceversa. i am unable to even ping each other using computer name or ipaddress. i cant map netwrok drive either. and i dont see them in the network map on vista laptop or xp machine.
i did everything suggested in this forum including:
1. enabling sharing on vista (network and sharing center). enable everything.
2. turn on file and printer sharing on xp
2a. run through network sharing wizard on xp.
3. sharing drives on both
4. create same user on both vista laptop and xp pc
5. they are on teh same workgroup
6. they can both access internet, but i cant access printer or shared folders on xp desktop from vista laptop.
7. turn off firewalls on both laptops
8. i have ESET anti-virus and its not blocking anything.
9. network type on vista is set to private.
the only way i can get them to see each other and share folders is by giving my xp desktop a static ip. but this makes the xp machine lose connection to the internet. i am guessing it loses internet connectivity because the router is setup to do dhcp.
Please help.
Seth
