Thanks for the direction....It may be fixed.....I thouroughly cleaned the inside of the PC this morning, fans, boards, GPU etc. an the system has been stable ever since. It had been crashing every hour or so. I will give it until tomorrow before I mark as resolved and if it crashes again I will rerun the program as you suggested. Thanks again.
I have this error on startup on a computer I'm working on... I cannot get the error information (It requires Windows to run, and the computer hits the error on the initial load then resets), and it is happening even with a complete hard drive wipe...is there any way I can get a solution?
