HP Deskjet 1050A J410 series will not print
  1. #1
    Newbie
    Vista Home Premium 32bit
    Local Time: 08:59 AM
    Hi there I am having trouble getting my new printer to print. Ive just installed it, prints a test page ok, but will not let me print anything else.
    Has anybody got any ideas what I need to do I tried it with my old Windows XP computer and it works fine?
  2. #2
    richc46's Avatar
    BSOD Squad
    Fairfield County, CT
    Windows 7 SP1 x64
    Local Time: 03:59 AM
    usa us connecticut
    Re: HP Deskjet 1050A J410 series will not print
    Should be an easy solution. Go to the HP site and download the most current driver. The fact that you can print a test page shows that the problem is with the connection between Vista and the computer.
  3. #3
    Newbie
      Thread Starter
    Thanks for the reply, I have un-installed and installed software a few times but still no change.I have downloaded drivers from HP Website but still will not print.
    I was told by HP to Add Local Printer and use generic driver 990c but this also failed.
  4. #4
    The Howling Wolves's Avatar
    Senior Member
    California
    Windows 7 Home Premium 64bit
    Local Time: 12:59 AM
    usa us california
    Try shutting your system down then unplug all printer connections.
    Reboot your system and then start plugging your printer connections back in.
    By doing this it will let your OS find your printer and should be good to go.
    It worked for me and my old HP deskjet printer.
    Dennis
  5. #5
    Newbie
      Thread Starter
    Quote Originally Posted by The Howling Wolves View Post
    Dennis
    Hi I tried this but still no joy,its frustrating it tells me my printer is installed and ready to use,but when I go to print it says printer not setup.
    Or if I Try adding printer I get this.
  6. #6
    richc46's Avatar
    BSOD Squad
    Windows 7 SP1 x64
    usa us connecticut
    Uninstall everything but the printer, modem and mouse. Then try the alternative method. Go to search and type add a printer and try to install.
    If that does not work, try, with all uninstalled, going to the website, again.
    If it does not work, go to search type devices and printers, do you see your printer?
    If you see your printer, uninstall the driver, make sure that you do not see your printer, anymore. Keep everything uninstalled. Turn printer on. Turn off computer. Now boot with computer on.
    http://h20000.www2.hp.com/bizsupport...riesId=4027462
    Edit: Before any of the above, after driver installation, boot the computer, leave the printer on and plugged in and see how it goes. Have patience, we will get this to work.
    If you are wired, try all the above in a different port.
    If nothing works, try using an XP driver, save it to your desktop and right click on it, and use compatiblity mode.
    Compatibility Mode
    What ever you try make sure that the old driver is completly uninstalled first, do that now. Make sure the picture is not shown in printers and devices.
    Then plug in printer, turn on, turn off computer and boot
    Now that I think about it, all the advice from me and Howling, again. This time, before each attempt make sure that the driver is completely remove. Make sure it does not show in Devices and Printers.
  7. #7
    Senior Member
    California
    usa us california
    I just looked at my printer's and devices and show my HP deskjet 6122 as 990c.
    What I did was uninstall the the 6122 rebooted and then went in an added the 990c.
    then:
    We will find a fix for your problem just be patient!
    THW
  8. #8
    Newbie
      Thread Starter
    Thanks for the help lads, im still trying to get it to work nothing working at the moment I thought I might have some luck with the XP drivers but the files were corrupt. Its got to be something simple,im going to leave it for tonight its driving me nuts
    I will try again tomorrow hopefully it will fix it self over night.
  9. #9
    richc46's Avatar
    BSOD Squad
    Windows 7 SP1 x64
    usa us connecticut
    Please be sure that you have removed all traces of the prior(s) drivers before attempting to install another.
  10. #10
    Newbie
      Thread Starter
    Ok I have started again I have reinstalled software/drivers off Cd and connected printer.
    I went to printer properties and tried to print test page, It failed.
    I then went to printer software page and clicked on customise your printer and had this error.
    I also had a look in device manager I can see the scanner listed but shouldnt there be printers in there?
    How can they say the printer is compatable with Vista when it doesnt recognise the drivers. I can plug it into my old Xp and it works.
Page 1 of 2 12 LastLast
HP Deskjet 1050A J410 series will not print problems?
HP Deskjet 3820 Installed but does not print Alex Boromisa Vista print fax & scan 6 19 Aug 2009
Vista doesn't print to an old HP Deskjet 870Cse printer (parallelconnection)... Ant Vista General 28 17 Oct 2007
Vista doesn't print to an old HP Deskjet 870Cse printer (parallelconnection)... Ant Vista hardware & devices 30 17 Oct 2007
Vista doesn't print to an old HP Deskjet 870Cse printer (parallelconnection)... Ant Vista print fax & scan 28 17 Oct 2007
Vista print dialog conflicts for HP Deskjet 970xci Phil Race Vista print fax & scan 3 24 Sep 2007
