| | #21 (permalink) |
| Vista Home Premium 32bit and Ubuntu 9.10 32bit | Re: Fan Setup for Best Airflow??? in the tempest you have plenty of room because the 120 fan way below where my cpu is.... it is actually a little below my gpu because of where my x16 slot is |
| | #22 (permalink) |
| Vista Home Premium 64bit | Re: Fan Setup for Best Airflow??? Oh really? That's a huge plus. My freakin' gfx card is so big that it would definitely benefit from that fan as well. hmmm... very nice to know. Thanks!!! |
| | #23 (permalink) |
| Vista Home Premium 32bit and Ubuntu 9.10 32bit | Re: Fan Setup for Best Airflow??? your welcome haha let us know what you choose |
| | #24 (permalink) |
| Vista Home Premium 64bit | Re: Fan Setup for Best Airflow??? I definitely will do! |
| | #25 (permalink) |
| Vista Home Premium 32bit and Ubuntu 9.10 32bit | Re: Fan Setup for Best Airflow??? haha ok |
| | #26 (permalink) |
| Vista Ultimate x64 | Re: Fan Setup for Best Airflow??? Heres some reviews for those cases. NZXT Tempest » Reviews - XSReviews.co.uk - Trusted Hardware Reviews Coolermaster HAF 932 » Reviews - XSReviews.co.uk - Trusted Hardware Reviews Lian Li PC-7FW Just pay attention to things like build quality, cooling, noise etc as in reviews they can mark down a case for not having enough optical drives or being ugly but if your not planning on having 5 dvd drives and you like the look of the case then thats not a problem for you Last edited by stew2; 03-19-2009 at 10:40 PM.. |
| | #27 (permalink) |
| Vista Home Premium 32bit and Ubuntu 9.10 32bit | Re: Fan Setup for Best Airflow??? the tempest is a little noisy.... but you can get silent fans for about $10 a peice but it is still in my room and i do sleep with it on but... bright lights haha |
| | #28 (permalink) |
| Vista Ultimate x64 SP1 | Re: Fan Setup for Best Airflow??? For airflow you could always try the Antec Skeleton. Antec - Skeleton Just close all running applications and leave it for a minute = idle temps. It doesn't have to be scientifically accurate, it is more of a 'near enough is good enough' kind of thing. |
| | #29 (permalink) |
| Vista Home Premium 64bit | Re: Fan Setup for Best Airflow??? For airflow you could always try the Antec Skeleton. Antec - Skeleton Just close all running applications and leave it for a minute = idle temps. It doesn't have to be scientifically accurate, it is more of a 'near enough is good enough' kind of thing. |
| | #30 (permalink) |
| Vista Home Premium 32bit and Ubuntu 9.10 32bit | Re: Fan Setup for Best Airflow??? haha a little to.... open for me haha |
| Corsair Dominator Airflow Fan | Overclocking & Cooling | |||
| Which Rig for Best Airflow??? | Overclocking & Cooling | |||
| Setup has now become Vista General II(Miscellaneous) instead of Setup | Vista installation & setup | |||
| Vista Beta 2 hangs during setup installation setup | Vista installation & setup | |||
| Windows Setup: setup.exe - Application Error | Vista installation & setup | |||
