| Guru of Gaming | help OC'ing E8400 with ASUS Mobo Ok here's the story. I have the Intel Core 2 Duo E8400 running at 3.00Ghz. I would like to run it at 3.75Ghz stable...and be able to run it at 4.00Ghz stable for gaming purposes. I have read around the web of people being able to clock these chips to 4.00Gh with ease and some even have it going up at 4.40Ghz too. So i am not very skilled when it comes to OC'ing, this will be my first OC. Could some help me out here. I don't know too much about voltages...and the other settings that go along side when OC'ing a cpu. As of now, all i have it change the FSB to acheive 3.6Ghz and above (but unstable). Well any help would be great appreciated. My Rig specs are on my profile for those of you who need it. CPU: Intel Core 2 Duo E8400 Mobo: ASUS P5N-T Deluxe RAM: OCz @ 800Mhz PSU: 750W Corsair VGA: 9800GTX+ (SLI) Please keep it very simple for me, as i do not know the entire vocabulary when it comes to talking about OC. So simple instructions please ![]() Thanks inadvance |
| ...... | Re: help OC'ing E8400 with ASUS Mobo First off you should google Overclocking and find as much about it as possible. Right were ready to begin The e8400 has a 9X multiplier and a base FSB clock of 333. So 9 X 333 = 3GHZ with 4 X 333 = 1333MHZ FSB.You want to acheive a 1:1 ratio between your cpu and ram. In your case your ram is 800mhz so a setting of 400 for the fsb is what you want. RAM = FSB x 2 So 400 x 2 will give you 800mhz If the E8400's FSB base clock is increased to 400 you get an OC of 3.6GHZ (400 X 9) with a FSB of 1600MHZ (4 X 400). |
| ...... | Re: help OC'ing E8400 with ASUS Mobo Go to your bios and reset to default values then boot and restart and go back into bios. To acheive RAM of 400 x 2 and cpu of 400 x 9 go into your bios. Disable speedstep for your cpu *SpeedStep Guide:* Then go to your tweaking tab and set the cpu, ram and AI overclocking values to manual. At this stage you can leave voltages at auto. The cpu value will be 333 you can try a setting of 343 which is a step up of 10 and ensure your ram is at 686mhz. Save changes and boot. If all went well go back into the bios and try 353 which means your ram will now be at 706. Continue this process until you reach 400 or until you hit a point it wont boot. |
| Guru of Gaming | Re: help OC'ing E8400 with ASUS Mobo till the point it won't boot? that would mean its unstable...so then i would track back to the stable point before it didn't boot? I will try this when I get home tonight. Thank you for the help, please check back here as i will probably have some more questions to ask later this evening. |
| ...... | Re: help OC'ing E8400 with ASUS Mobo If all went well youv achieved a fsb of 400 and its now time to tweak the voltages. Go to the cpu voltage and see what it currently is by setting it to manual. Your cpu is rated for operation between 0.85V – 1.3625V but really you dont want it near 1.3625V. Take it down one setting at a time and save changes and boot. Once you reach a value that it doesnt boot properly, lets say 1.125 then set it two places higher than that as thats normally enough to ensure good performance. |
| | #6 (permalink) |
| ...... | Re: help OC'ing E8400 with ASUS Mobo Yeah if you reach a point it wont boot its unstable so go back to your last stable overclock and post here listing where it wont go past. |
| | #7 (permalink) |
| im coming for cake | Re: help OC'ing E8400 with ASUS Mobo great info there stew2..... ![]() whilst finding you highest ''stable'' FSB i would loosen the RAM timings right off to 6-6-6-18, this will remove the possibility of your RAM becoming unstable as you raise the FSB on a 1-1 ratio, so it basically allows you to just work on the CPU for now... i'd leave all other voltages on ''Auto'' for now except ''VCORE & VDIMM'' raising the FSB in increments of 10mhz or 20mhz, keep going till it fails to post, then start adding in more VCORE, if it still fails to post no matter how much extra voltage you feed the CPU, add a little VDIMM (not too much, RAM frys very quickly), but this should allow you a few more increments... if it stops posting no matter what settings the above voltages are on, this is when the other ''sub'' voltages will come into play....... unfortunately every rig is different so from this point on its a case of trial & error ![]() now its impossible for you to fry the chip, the board has voltage fail safes to prevent damage. ![]() once you've reached your highest FSB (hopefully 4ghz+) this is when you can start to mess around with RAM settings, bring the timings back in to 5-5-5-15, if your able to run CL4 thats even better..but unlikely if its CL5 another setting to look at is the ''command rate'' if your RAM is good stuff it may be able to run ''1T'' timings instead of ''2T'', this will further increase performance, but again only certain RAM can do this... remember your RAM will be the first component to fail, so treat it with a little more love than anything else....lol , be ready for at least 40-50 reboots to get it stable, but its all part of the fun... SK |
| | #8 (permalink) |
| Guru of Gaming | Re: help OC'ing E8400 with ASUS Mobo thanks for the details guys. I will be playing with this tonight . I will post back with results and screenshots |
| | #9 (permalink) |
| ...... | Re: help OC'ing E8400 with ASUS Mobo Cheers skunksmash ![]() LukaszR remember this is what you have just now: CPU 333 x 9 = 3 Ghz FSB 333 x 4 = 1333 Mhz RAM ?????? RATIO ?????? This what you are aiming for: CPU 400 x 9 = 3.6 Ghz FSB 400 x 4 = 1600 Mhz RAM 400 x 2 = 800 Mhz @ 5-4-4-15 RATIO 1:1 Last edited by stew2; 04-06-2009 at 04:02 PM.. |
| | #10 (permalink) |
| Guru of Gaming | Re: help OC'ing E8400 with ASUS Mobo heres the exact ram sticks i have. Btw, running 8GB Canada Computers - Memory > Desktop Memory > DDR2 800 PC2-6400+ : OCZ (OCZ2P8004GK) DDR2 PC2-6400 Vista Performance Platinum 4GB (2x2048) Kit Dual Channel. |
| OCing e8400 with asus mobo | Overclocking & Cooling | |||
| Asus Mobo with Vista 64 Problems | General Discussion | |||
| RaZoR_GTX: ASUS A8N32-Sli-Deluxe Mobo | Vista General | |||
| ASUS P5B Vista Premium Mobo & Xi-Fi | Sound & Audio | |||
| Looking for Vista-compatible drivers for my ASUS P4B533-VM MOBO | Vista hardware & devices | |||
