1.    27 Mar 2012 #11
    Doncaster, UK
    Windows 8.1 Pro RTM x64
    Local Time: 03:20
    england uk yorkshire
    Re: no sound
    Take a look at this thread from the Dell community. It might help. No sound on Inspiron 531 - Desktop Audio Forum - Desktop - Dell Community
  2.    27 Mar 2012 #12
    vista home premium
    Local Time: 21:20
    Re: no sound
    I just reread your original post. Click on the white speaker with the red x. On the bottom of the resulting screen, you will see a speaker with a red x on it. click on that. The red x should disappear and you should have sound.
  3.    29 Mar 2012 #13
    x64
    Local Time: 19:20
    Re: no sound
    No Sound for me either. When I run a test on 2-High Definition Audio device (it is checked in green) the meter is bouncing but no sound???? I uninstalled one of the two realtek programs - well, now I don't see anything realtek, I may have uninstalled the other. Do you have the link to re-install realtek??
    This seems to be a BIG problem - The Geek Squad dude said I probably needed a new sound card. I am thinking it is something you Smart People can fix?????????????????
    Gateway
    Model - GT5676
    Processor - AMD Phenom, 9600 Quad-Core processor 2.30 ghz
    Memory - (RAM) 4.00 GB
    System Type - 64-Bit
  4.    29 Mar 2012 #14
    vista home premium
    Local Time: 21:20
    Re: no sound
    Did you get a CD with the mobo drivers with your system? If so, it should be on there. That would be for the onboard sound chipset.
    Do you have a discrete sound card?
    This is where the Realtek drivers are- http://www.realtek.com.tw/
  5.    29 Mar 2012 #15
    x64
    Local Time: 19:20
    Re: no sound
    No disk - I think they did everything at BestBuy. Discrete sound card??? Thanks for the link, but what do I download? This is not my area of expertise.
  6.    29 Mar 2012 #16
    vista home premium
    Local Time: 21:20
    Re: no sound
    A discrete card is one that you have to install on the motherboard. Most motherboards come with integrated audio chipsets.
    I would install v6.250. The only problem i have is that the site lists US1, US2, and US3 and I don't know what that means. I didn't try to find out at the website.
  7.    29 Mar 2012 #17
    x64
    Local Time: 19:20
    Re: no sound
    The descrete card will fix my issues, but you don't know which to download?
  8.    30 Mar 2012 #18
    x64
    Local Time: 19:20
    Re: no sound
    Where to go? What to download? How to fix?? You never really think about but, NO Sound is a real pain!!!!!!
    HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  9.    30 Mar 2012 #19
    x64
    Local Time: 19:20
    Re: no sound
    My computer is Stock so, No Discrete Card. My speaker systems is 5 Creative speakers, 4 are 4"x4" and one is a base/junction box 8"x8" The patch cord (2 plugs, Green/Black) run from the base/junction box to the computer. The 4 little speakers plug into the base/junction box as well as a control (on/off) volume dial. When you turn the dial on the light still comes on, power is running through the system. When a CD or a video is played all the audio meters bounce as if I am hearing it BUT - No sound! No Hum? Nothing out of the speakers! Like they are all disconnected or all muted?? HELPPPPPPPPPPPPPP!!!!!!!!!!!!!!!!!!
  10.    30 Mar 2012 #20
    x64
    Local Time: 19:20
    Re: no sound
    OK - In the last few weeks Microsoft has done 50 or so automatic updates on my computer! This has to be the problem!!!!!!!!! So????????????? I assume I need some of them? What to uninstall?
Page 2 of 5 FirstFirst 1234 ... LastLast
distorted sound in vista/createiv x-fi titanium sound card
It isn't always there...it comes and goes, but it's pretty ugly. I thought it might be a sample rate thing, but I changed those settings in control...
Sound & Audio
No sound when playing music or video, but internet sound works fine
Each time I try to play a song or video in wmp, itunes, VLC media player, InterVideo, etc. I get absolutely no sound. Videos play, I can see the...
Sound & Audio
Sound Problems - Vent, Xfire, Steam voice - no sound
I can hear sound in almost every program perfectly, exept for ventrilo, xfire speak, and steam voice. these ones i can talk but i cant hear...
Vista hardware & devices
Setting per Application Sound Output, or Per Sound Type Outputs...
OK folks. Fresh to the meat grinder, I installed Vista. Little did I know the torment that would ensue. I thought people were exaggerating when they...
Vista General
How to record sound clips or music using the sound recorder?
In XP i use to record sound clip using the sound recorder by modifying the sound control setting in XP. I forgot to do this in XP and now trying to...
Vista music pictures video
My Creative Sound Blaster X-FI Sound Card Works Now with Creative's RC1 Device Driver's! I Have Sound!
My Creative Sound Blaster X-FI Sound Card Works Now with Creative's RC1 Device Driver's! I Have Sound! Kevin John Panzke P.S. I am Running...
Vista General
Vista x64 RC2 - Sound Card/Amplifier - DTS Test Sound (Audigy 2 ZS SPDIF)
Hi, What is required for the DTS Test sound you can send through the SPDIF Settings to be decoded my my Surround Receiver/Amplifier? It...
Vista General
Our Sites
  • Ten Forums
  • Eight Forums
  • Seven Forums
  • PC Help Forum
  • Help Me Bake
  • Site Links
  • Contact Us
  • Privacy and Cookies
  • About Us
    Windows Vista Forums is an independent web site and has not been authorized, sponsored, or otherwise approved by Microsoft Corporation. "Windows 10" and related materials are trademarks of Microsoft Corp.
    Designer Media Ltd
