simondodgson
Any one having trouble with VIA USB 3.0 4 Port Internal PCI-e Hub
Before any one say's have you contacted VIA yes i have but thought i'd also ask the forum as well
I have downloaded the updated drivers from VIA support site ......... cleaned out any old copy of the drivers first rebooted Vista as well..... when to install the new drivers.......... once again install when find vista found the hardware and installed it rebooted after and once again when vista reloaded there was a yellow tri angle over the VIA USB 3 Root Hub and error is code 10 (This device cannot start) just like before under the Universal Serial Bus controllers option in control panel.
I am lost to know what to next is there any chance that you could send me the files
Via Hub3.inf
Xhcdrv.inf
ViaHub 3.sys
Xhcdrv.sys
Cos these are the files that are used to install the card pleas make sure they are for Windows Vista Ultimate SP2 32bit
and also are updated once two and I will try and do a manual install again if that does not work then I will try a different card to see if the card is at fault
Thanks Simon Dodgson
Via Hub3.inf
Xhcdrv.inf
ViaHub 3.sys
Xhcdrv.sys
- CUSTOM BUILD
- AMD
- GIGABYTE
- 16GB
- Graphics Card(s)
- AMD
- CREATIVE LABS
- DELL
