billionton bluetooth adptar driver problem
nelbulani
:huh: hi
looking for billionton bluetooth usb adptar 100mt class1 driver for vista32b.
please some body help me for that ..............
thanks
Hello Nel,
Try this driver, please. Let us know how it works.
Cheers...
    Gateway P7805u FX
    Intel PM45
    8GB 1066MHz DDR3
    LG 17" WUXGA TFT
    1920x 1200
    WD 2x500GB
    notebook
    BT/BD
thanks brother
i check its working but now softwer asking make your device discoverlabile and chang your connecting setting
please tell me how to do that in vista 32bt
thanks
I think it asks you to pair your PC with the device you want to use and connect to the computer using the bluetooth connection. It can be a phone, gps antenna, copy machine or bluetooth headset.
I don't have this software, so it's little hard for me to tell exactly how to do it in this case. But, if you want to connect the phone to the PC using the bluetooth for example, you have to set the phone to bluetooth connection, create the password etc.
Try to read the device manual or follow the steps provided by the bluetooth wizard.
Hope it helps. Cheers...
    Gateway P7805u FX
    Intel PM45
    8GB 1066MHz DDR3
    LG 17" WUXGA TFT
    1920x 1200
    WD 2x500GB
    notebook
    BT/BD
