Solved Blue Dot Crash
No not yet
Go to device manager and update the video card driver.
The device manager is telling me my drivers are up to date. But I had a little message pop up on the screen that said " At least one display adapter on the system has been disabled because its driver is not compatible with the driver for the VGA adapter ".
Should I take one of my video cards out of the computer and reinstall the driver? Or does it matter that I'm running 2 9800gts.
Dont you see a very small yellow marker by the driver? If so that was is bad.
Thats it then. That yellow marker is usually a driver problem, but rarely it can be the card. Update those drivers.
Still crashing. Brand new driver, device manager didn't have the yellow "!" beside them. I'm starting to think a bullet is the only way to fix this piece of crap.
Go to event viewer and give me the information about the crash (errors) that just happened. Code numbers etc.
Hello Matt40 wow you have been through a lot with this I was wondering if you can tell me how many factory disk's you have and what they say on the disk's.
Do you have anything on your computer that is needed, if not we can walk you through a complete factory install, this will put the computer back to what is was when you bought the computer, but anything you have done beyond that would not be saved unless it was backed up already. Just a thought?
Tom
    a6530f Desktop
    HP-PAVILION
    M2N68-LA (Narra3)
    LG W40 series widescreen
    1600 X 900
    300W
    Mid-Size ATX
    HP Multimedia Keyboard
    Microsoft Wireless Mouse 5000
    Processor: AMD Phenom X3 8450 Operating speed: Up to 2.1 GHz, Number of cores: 3, Socket: AM2+, Bus speed: 3600 MHz HT3 (clocked down to 2000 MHz)
    Modem: 56K WinModem/
    Supermulti: 16X DVD(+/-)R/RW 12X Ram (+/-)R DL Lightscribe SATA Drive
    Menory Card Reader: 15-in-1 Multimedia Card Reader
    Media Drive
I'll try anything at this point. The disks that came with the computer are my OS Disk, a disk for my sound card, a disk for my CD burner, a Dell Application disk, and a Dell Drivers and Utilities disk.
Hello first you put in your os disk and then shut off your computer and then restart and it will guide you through the procress, It might take a little while longer doing it this way but then all of your setting's will be like when it came from the factory. I know because I have had to do mine a couple of times it is time consuming but when your done it's like having a new computer.
Let us know before you start.
Tom
    a6530f Desktop
    HP-PAVILION
    M2N68-LA (Narra3)
    1600 X 900
    300W
    Mid-Size ATX
    Media Drive
Hello
Could you tell me if there is any sound coming from the hard drive at all.
Tom
    a6530f Desktop
    HP-PAVILION
    M2N68-LA (Narra3)
    1600 X 900
    300W
    Mid-Size ATX
    Media Drive
Hello I was re-reading all of the posts and would like to know if you were able to do any of the things that Rich asked you to do, I re-posted them at the bottom of this page so you can look them over again. If you have tried each one can you give us a breakdown of what happened with each one when you tried them.
Tom
When it comes to games, I do not have much to offer. I do, however, have this excellent thread on game problems; maybe it will give you some ideas.
Tips on Troubleshooting Game Issues - Windows 7 Forums
Here are my ideas on freezing
Here are my solutions to freezing, and an excellent article, which I hope is of some help
Go to search type device manager and look for any yellow warning markers
Download and run malwarebytes, a full scan after you update
Run antivirus scan
Check memory with memtest86
Make sure that you are not over heating.
Try in safe mode; report back if it works properly.
Try a clean boot
Make sure PSU is working properly
If overclocking, restore to original
Test hard drive at company website.
Test in safe mode, does it still happen?
Try with clean boot..
http://support.microsoft.com/kb/929135
http://www.geekstogo.com/forum/topic...ing-memtest86/
http://malwarebytes.org/
http://www.almico.com/speedfan.php
http://ezinearticles.com/?Troublesho...blems&id=39981
For the SFC Log
System Restore not completing successfully
    a6530f Desktop
    HP-PAVILION
    M2N68-LA (Narra3)
    1600 X 900
    300W
    Mid-Size ATX
    Media Drive
So I finally figured it out this evening, I opened up my machine and removed one of my video cards, it works fine now, been playing DC universe since about 8:30 pm.
Does that mean that one of my cards is faulty? Or maybe it was just overheating or something...Whatever the case is I really appreciate all the help you all gave me especially americancritic and richc46, you guys gave me hope when things looked their worst lol :D.
Try reseating the card and see if it still works.
Hello Matt40 as long as your computer is running and your able to use it the way you want that's what is all about. I am glad that we helped a little and good luck. Keep posting when you have a problem and we all wish you the very best.
americancritic
Tom
    a6530f Desktop
    HP-PAVILION
    M2N68-LA (Narra3)
    1600 X 900
    300W
    Mid-Size ATX
    Media Drive
