Buying Vista in USA Questions
w01f
Hello,
I'm off to the States next week and I'm very tempted to make the most of the amazing exchange rate and buy Vista Ultimate Retail as it would work out much cheaper.
I have a few questions before I do though...
1) Can I confirm that I would have no problems running Vista in the UK if bought from the USA?
2) Does Ultimate contain both 32-bit and 64-bit editions? I have a 32-bit system atm and intend to buy a new 64-bit computer later in the year, so would I still be able to use the same key to activate between the different PC's?
3) I will be staying in North Carolina, so can anyone recommend a decent retail store to buy Vista from please?
Many thanks!
Hmm I was sure I had already replied to this!
It will work fine.
Retail comes as both, oem is limited to the version you buy 32 or 64bit
Many thanks!
No idea, if you needed a supplier in Salford I could help you out lol
    Windows 11 Workstation
    Ryzen 9 5950X
    Creative
    Drive
    1500W ThermalTake Toughpower
    ThermalTake Level 10 GT
    Enermax Liqtech 240
    Surface Ergonomic.
    Logitech Performance MX
    350 Mb/s
    WinTV NovaTD
    HP CP1515n Color Laser
    Microsoft LifeCam Cinema
    APC 750i Smart UPS
    windows 10
    Surface Pro 3
    Intel HD Graphics 4400
    12" Multi Touch
    2160 x 144
    128GB
    yes
    350 Mb/s
Many thanks for your help!
If anyone from the USA can recommend a computer store (similar to pcworld here in the UK?) then I'll be mucho happy :)
Cheers
    1TB Samsung 990 PRO M.2,
    4TB Samsung 990 PRO PRO M.2,
    Galaxy S23 Plus phone
