svandewark
Here's what I've run into. Installed Vista Ultimate x64 on my harddrive and ran into a problem with my motherboard (Intel DP45SG). End result was that I could not boot my original installaton of Vista. BIOS related.
Tried all of the recovery options and none of them worked. Bit the bullet and reinstalled Vista fresh. Unfortunately I did not see the option to format the old info when I did this. This caused the old OS to be moved to it's own partition on my harddrive.
This old info on it's partition is only visible on Paragon Partition Manager 9 and not in Vista's Disk Management. Vista shows my harddrive as 936 GB instead of 1,000GB. I do not seem to have any way of accessing this partition or of getting rid of it. Paragon PM shows the partition as being unformated. When I try to format it or delete it with Paragon PM I get a message that this can only be done with the Recovery CD. This partition does not show up in the Recovery CD when it's run.
Any help would be appreciated. I don't want to give up 70gp of hard drive room just the hell of it!!
- Personal Build
- Core 2 E6550
- Intel DP45SG Extreme
- 4 GB Crucial DDR3 1333
- Graphics Card(s)
- EVGA 9600GSO
- Seagate 1T
- PSU
- 500W
- Case
- Antec Sonata III
- USB
- USB
